Hello guyes,
I just need a easy solution. just xplaining here:
I've brought a dvd disk which has 4 movies...so in the menu, total 4 still pics exist with 4 links (as .VOB format).
But I will write only 2 movies in the disk. So, I need to cut 2 pics with links which I dont need, nothing else & write with nero7.
So, how can I do it easily?
Thanks...
If you are happy with Nero then you can use Nero Recode. You can either re-author (and lose the menus), or replace the two title you don't want with a black screen that will take up very little space on the disc.
if you want to do a more professional removal job then you can try VobBlanker and PGCEdit (both free) or DVD Remake Pro (not free)Read my blog here.
Hi Guns1,
The nero encoder is 173 MB & not free. so just forget about nero...
I know bout "GUIForDVDAuthor", but problem arises while using this soft.
I wrote bout it before but no one answered.
For a DVD movie, it makes titles for every single file, But I need 1 title (with link) for totla movie (no matter how many VTS files contains in inside VEDIO_TS folder). But it's loading VTS_01.VOB as film1, VTS_02.VOB as film2....Not total movie as 1 title!!!
So, any advice plzzz.... -
Use VOB2MPG to extract the titles from the VOBs you have. This will give you 4 mpg files - one for each movie. You can then use these with GUIForDVDAuthor to create your new disc.
Read my blog here.
Authoring An Untouched Blu-Ray Movie File.
By mamasta in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Dec 2010, 22:02 -
Authoring a DVD home movie
By vikasa in forum Authoring (DVD)Replies: 29Last Post: 30th Aug 2008, 18:29 -
Movie freezes after authoring compliant DVD files
By mltwitz in forum Authoring (DVD)Replies: 15Last Post: 21st Dec 2007, 11:29 -
Is Vegas Movie Studio sufficient for authoring
By SearchQuality in forum Authoring (DVD)Replies: 2Last Post: 24th Nov 2007, 04:19 -
two titles in Main Movie authoring - which to use plus?
By dADDo in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2007, 00:34
