I just found that the a few video clips I get from HD PVR have some glitches (only a frame or two) when I played them in two different players at the same positions. I believe the signals were bad the HD PVR encoded them. I converted the video clips to AVCHD, the glitches were still there when I played them on my computer. But when I used PS3 to play the AVCHD video, the video part became jumpy for about 1 or 2 minutes and returned to normal. The audio part never had problem.
Is it possible to 'fix' the video file (.ts)? Or how can I prevent the 'jumpy' problem using PS3?
Is there a software to create avchd from mp4? I am thinking of converting the video clip to mp4 and then make avchd from it. Maybe the 'jumpy' problem is because h.264 decoder and mp4 could eliminate it?
Results 1 to 1 of 1
How to edit .WTV files from Hauppauge HD-PVR (H.264/AC3) in Adobe Premiere
By milOtis in forum User guidesReplies: 2Last Post: 12th Apr 2010, 05:04 -
Hauppauge HD PVR capture and jerky video issue
By Split Infinity in forum Capturing and VCRReplies: 0Last Post: 10th Apr 2010, 08:27 -
Hauppauge HD-PVR HD Video Recorder
By MooMoo in forum Capturing and VCRReplies: 2Last Post: 16th Dec 2009, 17:54 -
H.264 TS Cutter & hauppauge HD PVR
By unplug in forum EditingReplies: 0Last Post: 4th Oct 2008, 23:40 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04
