I'm hoping someone can help me out with a problem I'm having. I started with a project in iMovie prior to getting FCE. I logged over 500+ clips using iMovie, and once FCE was loaded on my computer, I imported the entire project from iMovie to FCE. The clips are all in DV format, which I've been told isn't the best format to use in FCE or FCP. Anyway, my problem is I can't add video filters to my clips (which I originally attributed to the DV format). I imported raw video footage that I have on my hard drive that is in AVI format, but that won't work either. I can't add video filters to any of my clips within this particular project. So I'm assuming now that I didn't set the preferences or settings correctly from the get go when I imported this project from iMovie.
Has anyone else ran into this problem or does anyone have suggestions that I can try out?
DV Stream is FINE for FCE and FCP.
Whoever said that must have either not known Mac specifics,
or likes to hear his / her own voice, even in saying something stupid.
The most likely problem is that your Project settings for FCP /FCE
aren't correct.
What happens if you create a new Project, set for DV-NTSC,
at DVD Spec ( 720 x 480) and simply create a new log Bin,
and import the footage DIRECTLY from where it is stored
on the HD, not the iMovie Project?
I believe this will fix your issue."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Getting Video To Import Into Final Cut Express
By 360Spider in forum MacReplies: 14Last Post: 6th Mar 2012, 09:21 -
Help Please! Exporting AVCHD video on Final Cut Express 4 - interlacing
By bs2511feist in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Apr 2011, 02:28 -
Corel video studio vs. Final Cut Express
By maverickluke in forum EditingReplies: 1Last Post: 9th Apr 2010, 10:05 -
Final Cut Express- splitting audio from video
By ker-plop in forum MacReplies: 10Last Post: 4th Jul 2008, 15:40 -
Pulling video from VOB formated CD for Final Cut Express HD
By nhdaveq in forum Authoring (DVD)Replies: 1Last Post: 2nd Aug 2007, 00:30
