  1. After I remove the previews from my DVDs using DVDFab, I have trouble playing them on my home DVD player. This is usually a problem with DVD's that are heavy on the previews (Disney). It only seems to be a major issue with my home DVD player, as my Xbox plays the DVDs just fine. However, my home DVD Player (a cheap LG DN191H) has a great deal of trouble getting past the part where the previews should be. Once it makes it to the menu, it plays the movie just fine, but it takes upwards of five to ten minutes to get there. The obvious answer would be to get a better DVD player, but I was curious to know if there was a way to, perhaps, alter the default navigation of the DVD after removing the previews, so the player doesn't try to access video that isn't there?
    May 2005
    Toronto ||*||
    Do a Full DVD with FixVTS
  3. 5 to 10 minutes? Usually, if nothing is done except to remove the Previews, it might take my player 5-10 seconds before hitting the menu. Anyway, running the finished DVD through FixVTS, as VirtualDoobMon suggests, should work. I'd do it differently by using PGCEdit to have it jump immediately to the menu by using its Trace Function and the Jump To PGC command. There's a good guide for this method here:
    http://www.digital-digest.com/~blutach/Jump2PGC/Jump2PGC_guide.html
