Hi I am using video redo to edit my video and its brilliant just add your markers then hit cut, however i cannot work out how to cut a single frame, does anybody know if it is possible...........
Thanks In Advance
Acestu
In theory it should be possible to do this. Do you want to remove a single frame or save it in a clipboard? If you want to remove a single frame, set the beginning and end of the video clip so that the end is 1 frame before and save that to the clipboard then mark the beginning of the frame after this frame and set the end point where you need, put that in a clipboard and join the 2 pieces together. It will give you the video minus one frame. If you want to save a single frame, I'd guess that putting the beginning and end marker on the same frame would work, but I've never tried it.
yes sometimes when i do a cut , it seems to leave one frame in there but the only way to delete it is to delete two frames which have the start and end points, i thought just a right click on the frame would give me the option to delete it but no. I also thought that setting the start point and end point on the same frame would work but it just deletes the whole thing, surely youmust be able to do this easily ?
Acestu -
Silly question?
Have you visited the VideoReDo forums for help? I remember seeing the answer to your question there.
http://www.videoredo.net/msgBoard/index.php
This might be a help. http://www.videoredo.net/msgBoard/showthread.php?t=5715 -
Thanks Tboneit I have left a Question on the Message Board
Cheers
Acestu
VideoRedo: Can't save format with commercials cut
By DarkPhoenix77 in forum Video ConversionReplies: 11Last Post: 19th Sep 2011, 11:39 -
Saving a single Frame as a Jpeg
By acestu in forum EditingReplies: 0Last Post: 20th Aug 2008, 15:11 -
VideoRedo->DVRMS Issue, VideoRedo->MPEG2 Fine, Please Help
By tbrnet in forum Video ConversionReplies: 0Last Post: 10th Jan 2008, 16:43 -
Adding Text to a Single Frame
By dogberry578 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2008, 16:03 -
What Video editor's can cut frame by frame?
By VEBouto in forum Newbie / General discussionsReplies: 19Last Post: 28th Oct 2007, 01:31
