Got Toshiba SD120E dvd player, remote is Toshiba SE-R0049. Trying to change region code on DVD, tried the post submitted, but I am being thick, there is no M on remote to activate the hack, Help. Bought new dvd for daughter and cannot play it as it is region 1.![]()
Many people say that the hack for another model works. See
https://www.videohelp.com/dvdhacks/toshiba-sd120e/1430
I've never seen a remote control with an M on it. Those instructions sound odd to me.
Do note that sometimes manufacturers change hardware and it does break hacks. If all else fails, it is possible to rip the DVD to your PC and re-burn it as a region free disc. Finally, note too that some region 1 DVDs will not play if the region of the DVD player is set to 0 (region free) and you must set the region to 1 to play these discs.
toshiba sd2010
By kibz in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2010, 01:58 -
Toshiba RD-XV48DTKB
By GT40 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Aug 2010, 08:36 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:57 -
Has Anybody Emailed Toshiba ??
By ofield1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Feb 2008, 08:31
