Hello
Im trying to convert a movie like I always used to do in the best using CovertXtoDVD. What happens is that it converts the movie then asks me to put in a DVD-R to burn it, I do this and select the lowest speed 4x.
I see a light on the burner like its showing that its being used and the progress bar is being filled however when it sais operation complete I pop in the disk into a dvd player and it doesnt work, then i tried to put in in my computer and its showing that its a blank disk. When I look at the disk mark on the back it looks as if its almost full... Does anybody know what could be wrong? Any help at all would be greatly appreciated . Thank you.
	Two suggestions: Try burning with ImgBurn, though I doubt that's your problem. And try a different brand of DVD media. What are you using at present?
 If you use ImgBurn, you will at least have a burn log, which may tell you the problem. You can post it here. Usually if a burner fails to burn properly, something in the software will alert you that there's a problem. Even poor quality media will burn, though you may end up with skips toward the end.
 Not too likely, but check that your software isn't set to just do a trial burn. If the disc seems to be burned, then either it's really messed up or your players just can't read it. I would try it on other set top players. It happens at times that the same burner that burned a disc can't read it. Not sure why.
 BTW, burners are cheap enough now, so if you have an older one, maybe time to replace. I burn SL 16X at 12X and I have yet to have a coaster unless I messed it up myself. But I use Verbatim and Taiyo Yuden DVD media and ImgBurn to burn. I have several different brand burners and they all work with no problems, even with Verbatim DL + media. And ConvertX is a very stable program and not too likely to mess up a conversion. I burn SL 16X at 12X and I have yet to have a coaster unless I messed it up myself. But I use Verbatim and Taiyo Yuden DVD media and ImgBurn to burn. I have several different brand burners and they all work with no problems, even with Verbatim DL + media. And ConvertX is a very stable program and not too likely to mess up a conversion.
	hey redwudz, thank you for being the only one to actually try and help me... Fortunetly I finally got it to work, what I did was I got a upgraded version of convertxtodvd... and I dont know if thats what made it work but I also used a Comp USA DVD-R instead of the Tayo Yuden I was using... I assume it was the program though that fixed it. Thanks again.!
  Authoring .MKV onto a blank Blu-Ray diskBy WBBIRL in forum Authoring (Blu-ray)Replies: 9Last Post: 3rd Oct 2010, 14:06
  Burner Won't Recognize Blank DVD-R DiscsBy ddowden1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Aug 2009, 07:52
  NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD'sBy renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 07:16
  Suddenly, burner doesn't recognize blank DVDBy slats7 in forum ComputerReplies: 9Last Post: 13th May 2008, 12:10
  Blank ReWriteable 8.5 DL Disk?By mlong30 in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2007, 22:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
