12
Last edited by Anonymous4; 11th Mar 2017 at 12:04. Reason: Scrubbing myself from the Internet.
i think the tinfoil hat should go on your head, as it's certainly not needed anywhere else.
Originally Posted by aedipuss
Donadagohvi (Cherokee for "Until we meet again") -
OK, I'll try to answer all that. Of course, JMO, though I have a few years of electronics knowledge.
Magnetic fields only emanate a few inches at best from any speaker in a level that could cause problems. Don't worry about it.
Your two wire VCR cord probably doesn't need shielding as it's power supply would filter out most line noise. Ground loops are a different matter, but shielding won't help with that. Just make sure all your grounds are returned to a common source. Most often this is the ground stake for your house power. If you have cable or satellite, it should also have a ground stake.
If you have decent audio cables, you should be set. Audio is low frequency, low power. Unless you have a poor connection, not likely to have interference problems. I have 50 ft HDMI cables and VGA cable of the same length. And my audio is distributed through the house on unshielded cable. No problems with any of them. If you lived next to a strong radio or TV transmitter, Or near a large industrial site that uses some forms of very strong RF energy, then you may have more problems.
Audio cables transmit alternating current most times. Magnetic interference is not really a problem.
If your grounds are solid, I wouldn't worry too much about thunderstorms, unless they tend to hit the power lines or the telephone lines nearby. A surge protector would be a wise investment, though. And if you want to unplug everything during a thunderstorm, go ahead.
If your VCR has a metal case, not likely anything will get through that, though anything is possible.
Bottom line, check your incoming power and communication systems and see that the ground stakes are firmly attached to the power box, the cable and the phone system. Try to use the same outlets for your critical devices, to avoid the possibility of ground loops.
And find other things to worry about.
Actually this probably belongs in the Newbie/General Forum. No offense. Moving you.
Most definitely.Originally Posted by DeXeSs
Yes, I suggest using a metal conduit pipe to shield.Originally Posted by DeXeSs
Input side, definitely.Originally Posted by DeXeSs
All interconncets should be cut as short as possible.Originally Posted by DeXeSs
That's an excellent idea.Originally Posted by DeXeSs
DittoOriginally Posted by DeXeSs
My only comment would be that it's not even possible to be too concerned about quality.Originally Posted by DeXeSs -
12
Last edited by Anonymous4; 11th Mar 2017 at 12:14. Reason: Scrubbing myself from the Internet.
x264 command line for max quality within Bluray spec?
By Asterra in forum Video ConversionReplies: 5Last Post: 5th Apr 2012, 16:22 -
From Point & Shoot Digital Camera AVI to Xvid High Quality
By kamil in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 10:28 -
Do Movie Maker or Virtualdub re-encode DV-AVI when saving? Quality concern?
By sdineen in forum Newbie / General discussionsReplies: 9Last Post: 18th Jul 2009, 22:47 -
Paranoia OR a good question? :o
By f-zer0 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Feb 2008, 23:32
