When I select Mpeg layer-3 for my audio compression the highest setting I can use is 56kBit/s. 24,000 Hz, Stereo. What do i have to do to get the higher quality encoding settings?
Somehow, your high quality l3codec.acm (I think that is the name) was replaced by the low quality windows standard version... that is, if you even had the high quality one to begin with.
Try finding the divx 3.11 alpha distribution file. Open it up and just take the acm file out of that and overwrite the one in the windows/system directory (or winnt/system32).
Then, you should have the high quality levels available again.
TheMamboMan -
just get radium... http://www.riphelp.com/downloads/radium_codec.html
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
I'd suggest you get the LAME mp3 codec. It's not only free, but it's A LOT better than the Fraunhofer codec.
http://home.pi.be/~mk442837/
Guiboche
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
How low can I make xvid bitrate and still play on new DVD player?
By jimdagys in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 22:07 -
MP3 track - low voice level
By Digiface in forum AudioReplies: 5Last Post: 30th Jul 2007, 18:05
