Hello:
I hope somone can help me with this.
I have these videos that supposedly are in .mpg format but when I open them in windows media player it says that the file has an .mpg extension that doesn't coincide with the file format, then I used GSpot to find out what codec was needed and it tells me that the file is ASF (WMV/WMA), now, the question is how do I correct this? do I have to re-encode it or convert it with some program?
I realle thank anybody that can help me.
codec need to play (wmv/wma) try diff player.
you wont convert if you cant decode first. -
Do the videos play if you rename the extension from .mpg to .wmv? Windows Media Player should be able to play those correctly.
Never heard of WMP ever reading a video and mentioning the format doesn't match the extension, though.
WebEx WMV to AVI or MPG
By jgq85 in forum Video ConversionReplies: 3Last Post: 19th Dec 2011, 09:57 -
stand alone MPG/WMV player
By confused2011 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 28th Nov 2011, 21:26 -
WMV and MPG to Xvid or MPG2?
By videohalp in forum Video ConversionReplies: 2Last Post: 27th Sep 2008, 23:16 -
.flv to .wmv or wmv. to mpg
By LITEONDVD in forum Video ConversionReplies: 5Last Post: 29th Jul 2007, 18:02 -
Converting WMV to MPG
By Datahead in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2007, 14:08
