I have tried the following:
I use DVDFab HD Decrypter to rip the episode first.
I select episode 1 and the correct subtitles I'm wanting.
I then use AutoGK and select the .IFO subtitle file.
In the subtitle box, I click the correct subtitle.
Click Add Job, and Start.
After a ways it says that the IFO can't be found and that subtitles is disabled...
Here is my AutoGK log:
Here is what I did in AutoGK:Code:[8/31/2008 10:56:05 AM] AutoGK 2.45 [8/31/2008 10:56:05 AM] OS: WinXP (5.1.2600).2 [8/31/2008 10:56:05 AM] Job started. [8/31/2008 10:56:05 AM] Indexing input for preview. [8/31/2008 10:56:21 AM] Processing file: C:\Documents and Settings\******\Desktop\NGEV01E01.vob [8/31/2008 10:56:21 AM] Source resolution: 720x480 [8/31/2008 10:56:21 AM] Found NTSC source. [8/31/2008 10:56:21 AM] Source aspect ratio: 4:3 [8/31/2008 10:56:21 AM] Color correction enabled. [8/31/2008 10:56:21 AM] Output will contain 42013 frames [8/31/2008 10:56:21 AM] Preparing subtitles for preview. [8/31/2008 10:56:21 AM] IFO file is not found. Subtitle processing is disabled. [8/31/2008 10:56:21 AM] Job finished. Total time: 15 seconds ==================================================== [8/31/2008 11:14:15 AM] AutoGK 2.45 [8/31/2008 11:14:15 AM] OS: WinXP (5.1.2600).2 [8/31/2008 11:14:15 AM] Job started. [8/31/2008 11:14:15 AM] Input file: C:\Documents and Settings\*****\Desktop\NGEV01E01.IFO [8/31/2008 11:14:15 AM] Output file: C:\Documents and Settings\******\Desktop\NGEV01E01.avi [8/31/2008 11:14:15 AM] Output codec: XviD [8/31/2008 11:14:15 AM] Audio 1: English AC3 6ch [8/31/2008 11:14:15 AM] Subtitles 1: English [8/31/2008 11:14:15 AM] Format: AVI [8/31/2008 11:14:15 AM] Target size: 175Mb [8/31/2008 11:14:15 AM] Custom resolution settings: fixed width of 640 pixels [8/31/2008 11:14:15 AM] Audio 1 settings: VBR MP3 with average bitrate: 128Kbps [8/31/2008 11:14:15 AM] Started encoding. [8/31/2008 11:14:15 AM] Demuxing and indexing. [8/31/2008 11:15:22 AM] Processing file: C:\Documents and Settings\******\Desktop\NGEV01E01.vob [8/31/2008 11:15:22 AM] Source resolution: 720x480 [8/31/2008 11:15:22 AM] Found NTSC source. [8/31/2008 11:15:22 AM] Source aspect ratio: 4:3 [8/31/2008 11:15:22 AM] Color correction enabled. [8/31/2008 11:15:22 AM] Analyzing source. [8/31/2008 11:16:27 AM] Source is considered to be hybrid (mostly FILM). [8/31/2008 11:16:27 AM] Looking for optimal hybrid thresholds. [8/31/2008 11:16:35 AM] Found threshold of: 1.46 [8/31/2008 11:16:35 AM] Output will contain 33610 frames [8/31/2008 11:16:35 AM] Decoding audio. [8/31/2008 11:17:11 AM] Normalizing audio. [8/31/2008 11:17:19 AM] Encoding audio. [8/31/2008 11:19:53 AM] Preparing subtitles. [8/31/2008 11:19:53 AM] IFO file is not found. Subtitle processing is disabled. [8/31/2008 11:19:53 AM] Audio1 size: 20,330,880 bytes (19.39 Mb) [8/31/2008 11:19:53 AM] Overhead: 1,344,384 bytes (1.28 Mb) [8/31/2008 11:19:53 AM] Video size: 161,825,536 bytes (154.33 Mb) [8/31/2008 11:19:53 AM] Running compressibility test. [8/31/2008 11:21:22 AM] Duration was: 1 minute, 29 seconds [8/31/2008 11:21:22 AM] Speed was: 22.57 fps. [8/31/2008 11:21:22 AM] Compressibility percentage is: 36.10 [8/31/2008 11:21:22 AM] Using softer resizer. [8/31/2008 11:21:22 AM] Chosen resolution is: 640x480 ( AR: 1.33 ) [8/31/2008 11:21:22 AM] Predicted comptest value is: 37.44% [8/31/2008 11:21:22 AM] Running first pass. [8/31/2008 11:39:11 AM] Duration was: 17 minutes 48 seconds [8/31/2008 11:39:11 AM] Speed was: 31.45 fps. [8/31/2008 11:39:11 AM] Expected quality of first pass size: 40.43% [8/31/2008 11:39:11 AM] Running second pass. [8/31/2008 11:57:26 AM] Duration was: 18 minutes 14 seconds [8/31/2008 11:57:26 AM] Speed was: 30.71 fps. [8/31/2008 11:57:26 AM] Job finished. Total time: 43 minutes 10 seconds ====================================================
What I'm trying to do is rip episodes and their subtitles, and then encode them together into avi.
Results 1 to 10 of 10
I would try keep all subtitles when ripping using DVDFab HD Decrypter and then just select the english sub in autogk.
Thats not the problem though.. Its that AutoGK isn't encoding the subtitles into the avi in the first place.. lol. Plus both subs are English, 1 is just for jap voice audio stream and 1 is for English audio stream.
Look at the log, and you can see AutoGK throwing out the subtitles.. so.. help please.. -
Extract the subs yourself and then add them to the AVI using the CTRL-F8 trick?
I can see where it could very well be the problem. Did you try what Baldrick suggested?Thats not the problem though -
All I have is the IFO file.. and I don't think I could put the IFO file int he f8 slot.. so can you tell me how to get the subtitles from the dvd? or would doing it the other way be the easy way? I'll try takign the episode and all subtitles.
Open the IFO in VobSub Configure and take it from there to extract the VobSubs (IDX/SUB). Here's a guide:
http://www.doom9.org/dvobsub.htm
The easy way? The easiest way would be to decrypt the entire episode, including all the sub tracks, at the very beginning and then let AutoGK do the work for you. I'd use DVDDecrypter in IFO Mode, assuming the DVD doesn't have any newer copy protections. -
i just got this:
I gotta work, so will have to mess with it later.
any avi converter to add subtitles (like on / off) like we use in dvd ?
By ashe09 in forum SubtitleReplies: 13Last Post: 19th Mar 2012, 06:59 -
Add permanent subtitles to S/VCD,DVD,AVI with ffdshow/vobsub
By Baldrick in forum User guidesReplies: 74Last Post: 4th Oct 2011, 05:11 -
permanently add subtitles to avi
By RZ_29 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2009, 10:57 -
How to add subtitles to AVI?
By sepehr_s in forum SubtitleReplies: 1Last Post: 16th Apr 2008, 15:10 -
how to add subtitles to an avi file so that my dvd would read it?
By Arwen-Katie89 in forum SubtitleReplies: 8Last Post: 13th Dec 2007, 12:02
