My HDTV, of 2 years, has started to show neon hot pink colors when the color should be black. This occurs after 10-15 minutes after turning on the TV, and stays for about 20-30 minutes, than goes away. I've done some quick troubleshooting: called the cable company (yes, I'm receiving the HD input); the hot pink replaces the black color even when watching DVDs. Has anyone experienced this problem? Or should I buy a new HDTV? Or send it in for repairs? The model is a no-name brand Norcent, 36". (I'm hesitant to buy a new HDTV if the repair is less than $300.)
I haven't experienced that problem before. But if the problem occurs on all the inputs, I strongly suspect the TV is shot. No-name TVs are difficult to fix because the makers frequently don't provide support to repair shops. I'd send it to the recycler and buy a name brand TV next time. Costo generally has a good selection and they automatically extend the warranty to two years.
Good Luck! -
Is this a direct view CRT? Rear projection CRT? DLP? ???Originally Posted by SLB131
If you google by model number you may find others with similar problems.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
That is an unusual failure mode for an LCD TV. If it isn't a cable/connector issue, it's probably a PC board failure.Originally Posted by SLB131Recommends: Kiva.org - Loans that change lives.
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 09:53 -
Green and pink static on HDTV after Blu Ray install
By Jake33383 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 3rd May 2010, 15:55 -
Subtitle problem that fills screen with pink
By oldjoe911 in forum SubtitleReplies: 2Last Post: 27th Oct 2008, 13:54 -
Problem with Pink Floyd Pulse DVD
By altsouza in forum Authoring (DVD)Replies: 9Last Post: 4th Sep 2008, 18:48 -
YpbPr on Hdtv only shows pink screen.
By tiagirl in forum Newbie / General discussionsReplies: 4Last Post: 14th Apr 2008, 12:18
