I have a 45 second interview with a bit of wind noise in the back ground. I have converted the audion from the video to a wav or mp3 and I have tried using audacity but have had no luck. I have not had to mess with the audio before so this is new to me.
I cannot re do the interview as it was taken on my vacation overseas.
I appreciate any info.
thanks
I have loaded the file.
koni%20wav.wav
It doesn't sound that bad to begin with. You can't remove the wind sound, but you can make it less noticeable.
1) Fade in the first 3 seconds and fade out the last 2 seconds.
2) Cut the bass frequencies below 90hz.
3) Add some dynamic range compression or limiting so the wind is never louder than the voice.
koni_modified.wav
Here are the frequencies removed by the above process. You'll notice a lot of rumble caused by the wind.
koni_freq_subtract.wav
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
Cutting out the wind noise from microphone mounted on car roof
By 872156 in forum AudioReplies: 6Last Post: 14th Jun 2009, 20:50 -
how can i remove wind noise from a audio track
By suomiaussie in forum AudioReplies: 2Last Post: 23rd Mar 2008, 09:10 -
Simple tool for Noise Reduction, Wind, Waves, etc
By Etherel15 in forum RestorationReplies: 1Last Post: 8th Jun 2007, 02:09 -
removing background noise
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 21:27
