I was wondering what program I could use to add some text when someone clicks on the menu. Either expand or come out from the top,side etc.. Here is a example hope you understand lol.
Menu some text
Menu
some text
Switched motion menus.
The DVD spec doesn't allow for a whole lot of control or interaction. To do what you want to you have a couple of choices.
The simple solution is one main menu, and a duplicate with expended text for each menu option. As the user moves up or down, the menus auto switch to the next appropriate menu screen.
The more complex solution is the same as above, but instead of jumping to a static menu, you switch to either a video clip showing the text expanding, then to the next menu, or to a motion menu that expands to achoice, then waits for the user.
Neither are really difficult, but you need to plan it out and create all the assets.Read my blog here.
Expanding the whole subtitle
By Night 89 in forum SubtitleReplies: 3Last Post: 2nd Jan 2012, 19:13 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Expanding AVI to eliminate line flicker
By yukon33 in forum EditingReplies: 1Last Post: 18th Feb 2008, 09:28 -
DVD-R not auto expanding to 16:9 like commerical DVDs
By neilalp in forum Authoring (DVD)Replies: 5Last Post: 13th Feb 2008, 22:04 -
Toast titanium 7, video expanding, cutting off stuff
By Kuramu in forum MacReplies: 3Last Post: 23rd May 2007, 16:49
