I have a Canon MVX430 DV camera that shoots in widescreen (16:9). When I capture to my PC, the video files are 16:9.
However, when I author them to DVD, they display as 16:9 with black borders on all four sides. MediaInfo reports these authored files to be 4:3.
I have tried at least three different DVD authoring programmes (WinDVD Creator, DVDFlick and something else) and they all give the same result.
Am I doing something wrong? How can I get my videos to show in full widescreen?
I'm not familiar with those programs but you need to change the authoring project preferences from 4:3 (forces letterbox) to wide 16:9. Also check the imported DV clip properties. Make sure all clips show as 16:9.Originally Posted by yurkyurk
Also, check MPeg2 encoding settings which also should show 16:9.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Do you load the avi files directly, or via avisynth ?
A 16:9 DV file has the same resolution as a 4:3 DV file. When loaded through avisynth, the 16:9 flag is lost, and this can cause some programs to read the file as 4:3 and encode and author as 4:3. I know that FAVC can be tricked by this, and has no override at present.
You can repair the DVD structure that you have already authored by using DVD Patcher on the VOBs and IFOAR2WS on the IFO files. This will change the DVD to be read as a widescreen (16:9) disc. So long as the authoring tools didn't letterbox the video, they should play back fine.Read my blog here.
I load the avi files directly. I'll have a look at those tools, but I'd prefer to prevent the problem than repair it afterwards. Thanks.
Why are there black bars at the sides?
By pooksahib in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2012, 09:11 -
How to crop the black lines out an MKV (and lose a bit of the sides)
By marklittlevai in forum EditingReplies: 32Last Post: 30th Sep 2011, 18:34 -
adding black to the sides of an image (windowboxing)
By maca in forum Video ConversionReplies: 3Last Post: 30th Jan 2010, 15:21 -
Black bars on sides of video...
By bla4free in forum Capturing and VCRReplies: 7Last Post: 1st May 2008, 08:55 -
WinTV PVR2 USB2 - Annoying Black Bars on sides.
By RedPenguin in forum Capturing and VCRReplies: 14Last Post: 15th Dec 2007, 19:42
