    Aug 2008
    Hello videohelp community. I've used the site quite a bit, but never had a problem before which required me to post. Usually I can find the answer, or software I need with a good search. Anyhow here's my problem this time.
    Is anyone here savvy with working with potentially corrupted video files? Yesterday I found that the majority of the video files I have stored on my external HD are unplayable, including about 50 sporting events and other downloads! It seems they are all .avi files and are not recognized as video files by any program, including Media Player, Gspot, video fixers, etc. I finally ran some through a hex editor and compared to a working .avi files, which I believe usually have somethinglike "RIFF...AVI LIST" in the first 16 bytes. Well, all the unplayable files show nothing in the hex editor, just 00's across the board. Any thoughts? I'm completely stuck...
  2. here's one thread.
    https://forum.videohelp.com/topic293355.html
    the problem will be that unless you know exactly what the resolution, framerate, codec with options - they were each encoded with i don't think anything is going to fix them.
    sounds like they were deleted and then you used a file recovery program to get them back?
    Aug 2008
    Thanks for the speedy reply and the link. I didn't recover the files or anything. The rest of the files on the drive seem fine. It seems like only the avi files have been affected, very strange.
  4. Hey guys, sorry for bringing up this really old thread, but when I tried following the instructions in slide show movie maker, i can't choose the codecs properly. It doesn't give the codecs for xvid or divx or anything at all. Same with audio, it doesn't show mp3 or anything. It shows microsoft video 1, cinepak codec, etc. I'm guessing maybe windows 7 and up aren't supported? What can I do instead to get this step acomplished?
  5. DECEASED
    Jun 2009
    Heaven
    First of all, start a brand-new topic, instead of hijacking ancient (AND UN-RELATED) ones.
