Hello, all. Happy Labor Day Weekend.
I'm having a problem with Windows Explorer & libavcodec.dll. Whenever I go to a directory with an AVI file in it, I'm getting a "Windows Explorer needs to shutdown" error box, and the message points to my libavcodec.dll file as the culprit.
This is a recent problem and I think I know the cause. I installed and uninstalled a crappy piece of software called "Tunebite", which monkeyed around with my codec structure.
Any ideas for solving the libavcodec glitch?
Thanks!
Results 1 to 9 of 9
Hi, pdr. Thanks for the reply.
Yes, I thankfully chucked Tunebite, and it was during the uninstall that things went wrong. The damn thing is junk!
I guess I'll try a reinstall of my codecs. (Windows Restore always seems to cause six problems for every one it solves.) -
It could be the thumbnail feature in Explorer causing problems. When you open a folder of AVIs, Explorer tries to generate a thumbnail for each video. It seems to be easy to cause problems with that feature, though.
Open a Run box, and enter 'regsvr32 /u shmedia.dll' (without the quotes). That should disable the thumbnail feature; see if it helps. If not, open the Run box again, and enter the same command - but this time, don't include the '/u'. That'll re-enable the feature.
libavcodec.dll is a part of ffdshow, I think. Not that I'm recommending uninstalling ffdshow just yet, but if you do have it installed, you can always try completely uninstalling it, then either seeing if the problem goes away, and/or getting the latest version and (re)installing that.If cameras add ten pounds, why would people want to eat them? -
Ai Haibara,
I know this is an old message, but if you are still using this message board, i registered here just to say thank you! And thank you topoisondeathray also.
The fix suggested in this thread worked perfectly. I followed the instructions given by Ai Haibara and i ran the command 'regsvr32 /u shmedia.dll'. But that alone did not fully fix the problem. I also visited the website for ffdshow and downloaded and installed the latest version of the software. Then i re-started my PC and now its working 100% again!
I'm very grateful to you guys for excellent and helpful advice. I had this problem on my PC for the last 2 years and i must have spent an un-countable number of hours trying to fix it. But now its completely fixed 100%.
Thank you guys for the help and support!
John. -
Glad I could be of some help.
You've lived with the problem (so to speak) for the past two years?
Ai Haibara,
Yes, roughly 2 years. For the last 2 years i have not been able to get into the "My Documents" folder on my PC. I had a kind of get-a-round worked out that allowed me to view the files in My Documents and if i quickly clicked the file, it would open but windows explorer would shut down. I tried so many things, i Googled so many different search words to find a way of stopping it, with no success........ Until now
Ai Haibara you help people who are in trouble. Its no different to what happens in the real world. To make an analogy, its like as if i had crippling back pain for the last two years, and you preformed a miracle and cured me
Thank you,
John in Ireland. -
Somehow, I doubt I was that helpful.
oh my god.. thank you very much >.<... thx fro bringing this things up,.. i've been worried in case i have to re-install my windows again >.<
thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 18:58 -
libavcodec x264 profiles
By Spearmint in forum ProgrammingReplies: 0Last Post: 2nd May 2011, 20:57 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 14:34 -
FreeEnc can't find libavcodec
By zakman in forum Video ConversionReplies: 2Last Post: 31st Jan 2009, 08:38 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 18:28
