i just came back from a vacation which i used both a Sony miniDV camcorder (shot video at 16:9) and a digital camera Canon 570IS (shot video at it's highest video quality 640, 30fps).. now I would like to transfer these videos to my PC using Sony Vegas 8 PRO and do some editing, question is which project setting should I use for Vegas?
You have two problems
1. You have a mix of framerates. The mini-DV shoots at 29.976 fps, while the still camera shoots at 30 fps. Over time this could introduce a small amount of audio delay. It may not be noticeable depending on how you cut.
2. You have a mix of formats. To deal with this you have four choices.
a) Create a 16:9 project so that the DV footage remains widescreen, and fit the 4:3 centre screen so that on a widescreen TV it is pillarboxed, and on a 4:3 TV it has borders all the way around
b) Set up a 4:3 project in Vegas, let the 16:9 material letterbox while the 4:3 fills the screen.
c) from 60 lines form the top and 60 from the bottom of the 4:3 material, then resize it back up to 720 x 480 so it becomes 16:9 footage. It will most likely result in the cropping off of heads in some scenes, but all the footage will be 1.78 : 1Read my blog here.
Project name and path are not taken
By Lehmeier in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2011, 10:53 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
GUI DVD Author Project default setting
By Genevieve in forum Authoring (DVD)Replies: 4Last Post: 29th Apr 2009, 01:10 -
Setting the layer break on a DVD9 (DVDLab Pro project)
By lorix in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2008, 11:19 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49
