Hi guys,
I have 2 XP systems with one happily producing error-free passes of FAVC.
The other produces many small frame errors in the second pass and can fail completely if I use both CPU cores. I suspect DiVX as the good system doesn't use it.
On checking the codecs I saw that the good one is using lvcodec2.dll, while the problem one is using i420vfw.dll, as well as having additionally mpg4c32.dll, ACDV.dll and DivX.dll. All other codecs are the same.
I changed the registry entry for VIDC.I420 from i420vfw.dll to lvcodec2.dll so as to be the same.
If I uninstal the DivX package I get the missing codec error.....
I don't understand how the good system works without DivX installed!
Any ideas as to what the good sytem is using - I am missing something here!![]()
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Problem with video passthrough codec
By Modemserf in forum ffmpegX general discussionReplies: 0Last Post: 19th Jan 2010, 22:01 -
my avi files only show video intermittently, not a codec problem.
By midwestcreative in forum Software PlayingReplies: 11Last Post: 18th Dec 2009, 16:55 -
Audio codec problem in Any Video Converter
By robo5050 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2008, 13:18 -
Weird problem with ----- video for windows/codec/playing/or i don't know
By RYGER in forum Software PlayingReplies: 11Last Post: 7th Sep 2008, 20:03
