Windows Vista...SATA hard drives.
I just added a second hardrive 750g to primary drive 300g. both segate
Initialized drive in windows Disk Management.
Used Seagates Disk Wizaed to set up and format drive.
Drive shows up in Windows explorer.
I cannot tranfer large files ( above 1G) to the new drive, operation locks up, Small documents are OK.
I also have a 120G USB external drive, I can tranfer all size files between primary and external drive.
Check everything, but cannot find any solution.
Any help will be appriciated
Results 1 to 10 of 10
is it formatted as ntfs? right click on the drive and select properties.
Did you format in NFTS of FAT32? FAT32 does not support file sizes above 1g.
I never, EVER, use HD setup tools that are foreign to the OS unless it is absolutely mandatory. Very sound and solid reasons for this policy have been repeatedly demonstrated over a long period of time.
You may just have a bad drive, or a problem with that particular channel, or the cable. These things are possibilities, one certainty is that the drive is NOT setup the way the OS, that would be the software responsible for reading from, and writing to, the drive, would have done it. -
go to the seagate website and get their disc checking software. sounds like it's defective to me. the software should give you the error code and then you can get an rma.
Follow up.
Went back to Comp USA to get drive tested, he said drive tested ok.
I ask him if he tranfered any large files, he said he could only test with small files but assured me drive is OK.
Reinstalled drive, still locked up during large file transfer.
Exchanged for new drive, it worked perfect.
PS: All disk check software showed defective drive to be OK -
Please descriabe in detail software methods used to partition, format, and prepare new drive for usage.
Problem with font size of added subtitle in MKV file and freezing pic
By tindrli in forum SubtitleReplies: 0Last Post: 24th Mar 2010, 11:47 -
Need a bigger system drive; how to transfer EVERYTHING?
By sdsumike619 in forum ComputerReplies: 16Last Post: 11th Apr 2008, 13:08 -
transfer to auxilary backup drive
By DrAlanStatham in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2008, 01:30 -
Audio CD with an avi file added
By Sskafar in forum AudioReplies: 3Last Post: 17th Dec 2007, 21:19 -
File and Transfer Settings Wizard Problem. Can't copy several files
By presto in forum ComputerReplies: 7Last Post: 24th Oct 2007, 08:19
