I have a new laptop Sony AR61M and when I burn videos to DVD and try to play in my home DVD player the video skips and freezes a lot![]()
I use DVD flick v1.3.0.0 to convert and burn seperatly with ImgBurn v2.4.2.0, I have also burned straight from DVD flick.
The last 2 times I have done this using my laptop both times I have ended up with unwatchable DVD's but all the other times I've done this is with a different laptop and a external DVD burner (the disk drive didnt work for that laptop) and had no problems what so ever.
I always use the same batch of DVD-R disks and I have burned audio CD's successfully with the laptop.
Is there a way to test the drive or even the divx/avi files i used for some sort of errors?
Results 1 to 14 of 14
playback of the dvd's in my laptop are fine its just when i put them in home dvd players.
Can it still be disk compatibility problem? -
or the home dvd player is shot..............I've had burnt dvd's that play fine in my oppo but not on my jvc.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
I just tried to burn the disk again, I burned the iso that was created earlier but this time I did the verify process because I accidently skipped it last time cause the disk ejected so I thought it was done.
This time I closed the disk tray and it started to verify but it failed with this problem
what is this? -
Heres the log
I 19:12:25 ImgBurn Version 2.4.2.0 started!
I 19:12:25 Microsoft Windows Vista Home Premium Edition (6.0, Build 6000)
I 19:12:25 Total Physical Memory: 2,094,912 KB - Available: 1,226,424 KB
I 19:12:25 Initialising SPTI...
I 19:12:25 Searching for SCSI / ATAPI devices...
I 19:12:25 Found 1 DVD±RW/RAM!
I 19:13:46 Operation Started!
I 19:13:46 Source File: C:\Users\costco\Desktop\New Folder\dvd.iso
I 19:13:46 Source File Sectors: 2,263,904 (MODE1/2048)
I 19:13:46 Source File Size: 4,636,475,392 bytes
I 19:13:46 Source File Volume Identifier: DVD
I 19:13:46 Source File Volume Set Identifier: 391C82F800228B51
I 19:13:46 Source File Application Identifier: IMGBURN V2.4.1.0 - THE ULTIMATE IMAGE BURNER!
I 19:13:46 Source File Implementation Identifier: ImgBurn
I 19:13:46 Source File File System(s): ISO9660, UDF (1.02)
I 19:13:46 Destination Device: [1:0:0] MATSHITA BD-CMB UJ-120 1.01 (F
(ATA)
I 19:13:46 Destination Media Type: DVD-R (Disc ID: CMC MAG. AE1) (Speeds: 2x, 4x, 6x, 8x)
I 19:13:46 Destination Media Sectors: 2,298,496
I 19:13:46 Write Mode: DVD
I 19:13:46 Write Type: DAO
I 19:13:46 Write Speed: MAX
I 19:13:46 Link Size: Auto
I 19:13:46 Test Mode: No
I 19:13:46 OPC: No
I 19:13:46 BURN-Proof: Enabled
I 19:13:48 Filling Buffer... (40 MB)
I 19:13:51 Writing LeadIn...
I 19:14:11 Writing Session 1 of 1... (1 Track, LBA: 0 - 2263903)
I 19:14:11 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2263903)
I 19:26:17 Synchronising Cache...
I 19:27:11 Exporting Graph Data...
I 19:27:11 Graph Data File: C:\Users\costco\AppData\Roaming\ImgBurn\Graph Data Files\MATSHITA_BD-CMB_UJ-120_1.01_30-AUGUST-2008_19-13_CMC_MAG._AE1_MAX.ibg
I 19:27:11 Export Successfully Completed!
I 19:27:11 Operation Successfully Completed! - Duration: 00:13:25
I 19:27:11 Average Write Rate: 6,236 KB/s (4.5x) - Maximum Write Rate: 8,572 KB/s (6.2x)
I 19:27:11 Cycling Tray before Verify...
W 19:27:47 Waiting for device to become ready...
I 19:27:49 Device Ready!
I 19:27:51 Operation Started!
I 19:27:51 Source Device: [1:0:0] MATSHITA BD-CMB UJ-120 1.01 (F
(ATA)
I 19:27:51 Source Media Type: DVD-R (Book Type: DVD-R) (Disc ID: CMC MAG. AE1) (Speeds: 2x, 4x, 6x)
I 19:27:51 Image File: C:\Users\costco\Desktop\New Folder\dvd.iso
I 19:27:51 Image File Sectors: 2,263,904 (MODE1/2048)
I 19:27:51 Image File Size: 4,636,475,392 bytes
I 19:27:51 Image File Volume Identifier: DVD
I 19:27:51 Image File Volume Set Identifier: 391C82F800228B51
I 19:27:51 Image File Application Identifier: IMGBURN V2.4.1.0 - THE ULTIMATE IMAGE BURNER!
I 19:27:51 Image File Implementation Identifier: ImgBurn
I 19:27:51 Image File File System(s): ISO9660, UDF (1.02)
I 19:27:51 Read Speed (Data/Audio): MAX / MAX
I 19:27:51 Verifying Session 1 of 1... (1 Track, LBA: 0 - 2263903)
I 19:27:51 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 2263903)
W 19:40:10 Failed to Read Sector 1008768 - Reason: Unrecovered Read Error
W 19:40:10 Sector 1008768 maps to File: \VIDEO_TS\VTS_01_2.VOB
W 19:40:15 Failed to Read Sector 1008769 - Reason: Unrecovered Read Error
W 19:40:15 Sector 1008769 maps to File: \VIDEO_TS\VTS_01_2.VOB
W 19:40:19 Failed to Read Sector 1008770 - Reason: Unrecovered Read Error
W 19:40:19 Sector 1008770 maps to File: \VIDEO_TS\VTS_01_2.VOB
E 19:40:23 Failed to Read Sector 1008771 - Reason: Unrecovered Read Error
E 19:40:23 Sector 1008771 maps to File: \VIDEO_TS\VTS_01_2.VOB
E 19:40:23 Failed to Verify Sectors!
I 19:40:23 Exporting Graph Data...
I 19:40:23 Graph Data File: C:\Users\costco\AppData\Roaming\ImgBurn\Graph Data Files\MATSHITA_BD-CMB_UJ-120_1.01_30-AUGUST-2008_19-13_CMC_MAG._AE1_MAX.ibg
I 19:40:23 Export Successfully Completed!
E 19:40:23 Operation Failed! - Duration: 00:12:31
I 19:40:23 Average Verify Rate: 2,686 KB/s (1.9x) - Maximum Verify Rate: 8,345 KB/s (6.0x) -
CMC Magnetics is crappy media. Try Verbatim of Taiyo Yuden.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Im planning on buying some Verbatim disks, minidv2dvd suggested I should try better disks too.
Is the problem because of the media? -
usually is, if the burner is reasonable new , try a burner cleaning disc, the type with the little brushes on a dic.
right then, I should stop making coasters and wait untill I get some Verbatim's
oh noooooo
I just bought some Verbatim dvd-r's http://www.pcworld.co.uk/martprd/store/pcw_page.jsp?BV_SessionID=@@@@0510795122.122029...ory_oid=-24872
Did the same thing, converted avi to iso using DVD Flick then burn with ImgBurn but the verifing process had a error again
I burned ok but failed the verify, does that mean bad file because it can be bad disk again....can it? Can you test a file for errors?
I 20:27:30 ImgBurn Version 2.4.2.0 started!
I 20:27:30 Microsoft Windows Vista Home Premium Edition (6.0, Build 6000)
I 20:27:30 Total Physical Memory: 2,094,912 KB - Available: 1,025,184 KB
I 20:27:31 Initialising SPTI...
I 20:27:31 Searching for SCSI / ATAPI devices...
I 20:27:31 Found 1 DVD±RW/RAM!
I 20:33:17 Operation Started!
I 20:33:17 Source File: C:\Users\costco\Desktop\dvd.iso
I 20:33:17 Source File Sectors: 2,263,904 (MODE1/2048)
I 20:33:17 Source File Size: 4,636,475,392 bytes
I 20:33:17 Source File Volume Identifier: DVD
I 20:33:17 Source File Volume Set Identifier: 391EAC8200228B51
I 20:33:17 Source File Application Identifier: IMGBURN V2.4.1.0 - THE ULTIMATE IMAGE BURNER!
I 20:33:18 Source File Implementation Identifier: ImgBurn
I 20:33:18 Source File File System(s): ISO9660, UDF (1.02)
I 20:33:18 Destination Device: [1:0:0] MATSHITA BD-CMB UJ-120 1.01 (F
(ATA)
I 20:33:18 Destination Media Type: DVD-R (Disc ID: MCC 03RG20) (Speeds: 2x, 4x, 6x, 8x)
I 20:33:18 Destination Media Sectors: 2,298,496
I 20:33:18 Write Mode: DVD
I 20:33:18 Write Type: DAO
I 20:33:18 Write Speed: MAX
I 20:33:18 Link Size: Auto
I 20:33:18 Test Mode: No
I 20:33:18 OPC: No
I 20:33:18 BURN-Proof: Enabled
I 20:33:20 Filling Buffer... (40 MB)
I 20:33:22 Writing LeadIn...
I 20:33:37 Writing Session 1 of 1... (1 Track, LBA: 0 - 2263903)
I 20:33:37 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2263903)
I 20:45:26 Synchronising Cache...
I 20:46:17 Exporting Graph Data...
I 20:46:17 Graph Data File: C:\Users\costco\AppData\Roaming\ImgBurn\Graph Data Files\MATSHITA_BD-CMB_UJ-120_1.01_01-SEPTEMBER-2008_20-33_MCC_03RG20_MAX.ibg
I 20:46:17 Export Successfully Completed!
I 20:46:17 Operation Successfully Completed! - Duration: 00:12:59
I 20:46:17 Average Write Rate: 6,395 KB/s (4.6x) - Maximum Write Rate: 11,456 KB/s (8.3x)
I 20:46:17 Cycling Tray before Verify...
I 20:46:43 Device Ready!
I 20:46:44 Operation Started!
I 20:46:44 Source Device: [1:0:0] MATSHITA BD-CMB UJ-120 1.01 (F
(ATA)
I 20:46:44 Source Media Type: DVD-R (Book Type: DVD-R) (Disc ID: MCC 03RG20) (Speeds: 2x, 4x, 6x, 8x)
I 20:46:44 Image File: C:\Users\costco\Desktop\dvd.iso
I 20:46:44 Image File Sectors: 2,263,904 (MODE1/2048)
I 20:46:44 Image File Size: 4,636,475,392 bytes
I 20:46:44 Image File Volume Identifier: DVD
I 20:46:44 Image File Volume Set Identifier: 391EAC8200228B51
I 20:46:44 Image File Application Identifier: IMGBURN V2.4.1.0 - THE ULTIMATE IMAGE BURNER!
I 20:46:44 Image File Implementation Identifier: ImgBurn
I 20:46:44 Image File File System(s): ISO9660, UDF (1.02)
I 20:46:44 Read Speed (Data/Audio): MAX / MAX
I 20:46:44 Verifying Session 1 of 1... (1 Track, LBA: 0 - 2263903)
I 20:46:44 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 2263903)
W 20:57:02 Failed to Read Sector 852176 - Reason: ID CRC or ECC Error
W 20:57:02 Sector 852176 maps to File: \VIDEO_TS\VTS_01_2.VOB
E 20:57:08 Failed to Read Sector 852177 - Reason: ID CRC or ECC Error
E 20:57:08 Sector 852177 maps to File: \VIDEO_TS\VTS_01_2.VOB
E 20:57:08 Failed to Verify Sectors!
I 20:57:08 Exporting Graph Data...
I 20:57:08 Graph Data File: C:\Users\costco\AppData\Roaming\ImgBurn\Graph Data Files\MATSHITA_BD-CMB_UJ-120_1.01_01-SEPTEMBER-2008_20-33_MCC_03RG20_MAX.ibg
I 20:57:08 Export Successfully Completed!
E 20:57:08 Operation Failed! - Duration: 00:10:23
I 20:57:08 Average Verify Rate: 2,735 KB/s (2.0x) - Maximum Verify Rate: 7,929 KB/s (5.7x) -
Tbag,
Since your burner is only burning the 16x Verbatim disks at 8x anyway, and I've seen much more discussion of the worth of the 16x than the 8x (both Verbatim), it would probably be worth getting even just one of the 8x Verbatims to try.
Other than that, the burner thinks it burned the data correctly to the disk, but has problems reading the disk it just burned. If you get the same result when using 8x (or 4x) Verbatims, there's nobody left to blame but the drive. -
Also, perhaps, may be...........
Too many other programs running, defrag your drive, virus check?
In control panel , uninstall the drive, re-bbot and reinstall it.
Dvd burning problems and frustration
By zubiri in forum Authoring (DVD)Replies: 14Last Post: 27th Sep 2010, 20:19 -
audio problems when burning a DVD
By cosypete in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 18:23 -
Problems with DVD burning for backup
By DDieggo1000 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jul 2009, 23:36 -
DVD download Burning problems
By completeidiot in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 05:53 -
DVD burning problems
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 00:11
