I just posted this question in the Newbie section, then I realized this forum existed.
I'm compiling a "Best Of" dvd of some of my concerts. Some of the audio is really quiet. Is there a way to normalize the audio of all the clip in Adobe Encore CS3 or do I have to use something else?
I use this app for music vid collections. Not only does it normalize but it will also standardize all the various audio to whatever you choose.
http://www.womble.com/products/dvd.html -
Are the videos already in mpeg2 format? (i.e not avi, mov etc).
You mentioned Encore CS3, since it only comes with Premier CS3 so I suggest you use Premier to do both the video and audio editing. The Audio editor allows for some audio cleaning, enhancements and volume control.
Once you are done with the editing, mark the chapter points and chose "Export to Encore" or Export the edit as mpeg2-dvd files for burning with Encore later on.
How do you use Adobe Encore CS3?
By Banleno007 in forum Authoring (DVD)Replies: 2Last Post: 20th Feb 2012, 11:33 -
Normalize audio in Adobe Encore CS3?
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2008, 12:40 -
Exporting from Premiere CS3 on PC to use in Encore CS3 on Mac
By meltait in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2008, 14:15 -
By zanos in forum Authoring (DVD)Replies: 0Last Post: 24th Apr 2008, 21:04 -
Adobe Encore CS3 - quick way to create 100 menu links?
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 4th Apr 2008, 22:17
