Hello,
I'm compiling a "Best Of" DVD of songs from my various concert DVD's, but the audio on some of the songs are very quiet. I'm using Adobe Encore CS3, is there a way to normalize the audio of all the clips from with it, or do I have to use a different program?
If it's not possible with adobe encore I would demux the ac3 tracks(using for example pgcdemux) and use this method: https://forum.videohelp.com/topic317891.html. Then add the ac3 files in adobe encore.
edit: Or it's mainly to increase the volume...
How do you use Adobe Encore CS3?
By Banleno007 in forum Authoring (DVD)Replies: 2Last Post: 20th Feb 2012, 11:33 -
Normalize audio in Adobe Encore CS3?
By Benhermies in forum Authoring (DVD)Replies: 3Last Post: 31st Aug 2008, 02:11 -
Exporting from Premiere CS3 on PC to use in Encore CS3 on Mac
By meltait in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2008, 14:15 -
By zanos in forum Authoring (DVD)Replies: 0Last Post: 24th Apr 2008, 21:04 -
Adobe Encore CS3 - quick way to create 100 menu links?
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 4th Apr 2008, 22:17
