Hi,
I usually backup my personal DVDs to avi (xvid) with Fairuse Wizard.
From DVD I also use Fairuse to create ipod mp4 movies for an ipod nano 3rd generation.
It displays only 320x240, but will accept up to 640x480 h.264 or mp4.
I have many movies already converted to avi (xvid).
I was wondering if it is possible to reencode to h.264 and ipod audio using Virtualdub which I am used to.
thanks in advance
8)
Results 1 to 9 of 9
I have successfully used videora for my ipod conversions at highest quality 640 x nnn. The quality is as good as you can get for the limitations of the ipod. Xvid4PSP also has presets for ipods and is very configurable. It has pretty much taken over from everything but AutoGK on my system.
You can't use virtualdub because it is limited to outputting to the avi container, which is not ipod compatible.Read my blog here.
Try freeware from : http://www.dvdvideosoft.com/products/dvd/Free-Video-to-iPod-Converter.htm
thanks to all for the suggestions!
I will try them all in order:
videora
Xvid4PSP
MPEG Streamclip
and pick the one that suits me best.
8) -
XVID4PSP is simply awesome ... although I don't have an iPod I have used XVID4PSP for a variety of conversions but I like it for the ability to do MP4.
Hi,
Try This:
http://www.bandshed.net/3GP.html
Far less footprint on the system than SUPER and the other previous mentioned ones.
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 03:15 -
Converting AVI to iPod h.264 preset
By oldskoolboarder in forum ffmpegX general discussionReplies: 1Last Post: 29th Oct 2007, 17:17 -
What is the best program to convert from H.264 mp4 to H.264 avi?
By Stealth3si in forum Video ConversionReplies: 6Last Post: 15th Sep 2007, 11:11 -
XviD.TG.avi convert to iPod.
By kieran_92 in forum Video ConversionReplies: 7Last Post: 3rd Aug 2007, 06:20 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
