Hi,
I guess this issue has been discussed before, but I made a search and can't find anything that solved my problem.
I can't get to work Vobsub 2.23 in Windows Vista 64bits. When I try to launch any of the program components it says "error loading vobsub.dll".
I would appreciate some help. Thank you in advance.
As Vobsub seems not to work in Vista 64 I'm looking for another application capable to rip subtitles into idx/sub format, but for the moment I didn't find any. I tried ImTOO subtitle ripper, but it rips totally wrong the idx/ sub.
Is there another program apart from Vobsub to get the idx/sub format? -
I do have a suggestion. It's ugly, but it should work.
VMware (http://www.vmware.com) has a free version of their server product. Download it and install it and if you have a 32 bit copy of XP, install XP to it.
You can run 32 bit XP in a virutal machine under Vista and Vobsub should work in it.
This is yet another reason to hate Vista. -
Thanks. That's a possibility.
I have XP installed in other partition. I'm wondering if it's quicker to use XP in a virtual machine or shutdown Windows Vista and restart with the XP, just to use those programs that don't work properly in Vista.
Probably is quicker to use XP in the virtual machine, I have no idea. -
MKV2VOB Problem in Windows Vista
By aras298 in forum Video ConversionReplies: 3Last Post: 24th Mar 2010, 04:43 -
Installing VobSub in Vista X64
By ks47 in forum SubtitleReplies: 2Last Post: 16th Jun 2009, 02:07 -
Vista 64 bits with 32 bits programs
By skaleton in forum ComputerReplies: 9Last Post: 15th May 2009, 11:41 -
VobSub Vista X64 Support?
By Shivek in forum SubtitleReplies: 0Last Post: 26th Jan 2009, 07:12 -
Windows Vista Problem :(
By 1magus in forum DVD RippingReplies: 5Last Post: 24th Jul 2007, 22:08
