Hi all,
I have recently changed to a new PC running Vista. I use a Hauppauge PVR USB-2 capture device. My problem is that I used to use WinDVD Recorder Platinum 5, but it appears that it doesn't work with Vista. So I need some similar software that I can use with my device and wondered if anyone had any advice.
Post recording, I do various editing and so forth and then use DVDLab Pro to author. I like to be able to capture at different bitrates which helps me size in advance for fitting to a disc, so I'd like to keep that functionality if possible.
Cheers in advance for any advice
Jub
Why not use the hauppauge software? Or do you want more settings?
Problems running software to capture PS3 game play?
By Agent 0008 in forum Capturing and VCRReplies: 9Last Post: 31st Mar 2011, 16:50 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
DV to PC -- Firewire Problems; 1394 vs. USB; Capture Software
By GrayStrickland in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2010, 11:27 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Software for Capture
By ashkan_vpm2 in forum Capturing and VCRReplies: 1Last Post: 6th Feb 2009, 14:03
