Hello
I am restoring some video and I want to use Topaz and Film fix. Now the problem is, both these filters say they can only work if you deinterlace the video first. Now I know there is a lot of debate about this, but I want to use the expensive tools I bought. The video I am working with was once PAL FILM. It then got transfered to NTSC video 29.9. What would be the best method to deinterlace, I ask only because it's very confusing with all the different options. I'm thinking that because my video was once film that may play a part. I want to keep it NTSC, but make it so I can use these filters. I Also I tried deinterlacing using Vegas and Tmpge and when I go to use these filters it still says the footage is Interlaced! Now Topaz has it's own Deinterlace tool, and I tried using it, but when you select it, the preview screen goes black with green vertical lines and when it's done rendering, that's all you get, a black screen with sound? When i tried to select NTSC progressive outtput with Tmpge, it rendered and then I imported the footage into Adobe to work with Topaz, and guess what? It still says it's interlaced! These are the tools I have avalable
Vegas pro 8
Adobe After Effects CS3 with the Topaz filter
Tmpge 4
Virtual Dubb
Grass Valley pro-coder 3
I also have many filters, I have tried all these, and I can't seem to deinterlace this footage, or After Effects does not see it as deinterlaced. I tried using G Spot to check, but it is not checked either way
Results 1 to 1 of 1
A few deinterlacing questions...
By SBPP in forum Newbie / General discussionsReplies: 4Last Post: 17th Nov 2009, 00:42 -
What is going on with Deinterlacing?!?!
By jieve in forum DVD RippingReplies: 30Last Post: 9th Aug 2009, 16:23 -
OS X Deinterlacing
By ggp759 in forum MacReplies: 4Last Post: 22nd May 2008, 17:37 -
Deinterlacing question
By Newbie 332 in forum Video ConversionReplies: 3Last Post: 15th Oct 2007, 21:50 -
How to use the deinterlacing in the TV when using the TV out from the PC?
By erik1958 in forum Software PlayingReplies: 2Last Post: 9th Jul 2007, 15:07
