I needed a vertical split between two iso cameras. I could not get the keyframe controls to stop a wipe during the transition.
Can wipe transitions in Vegas 8 Platinum be set to hold at 50% while the action continues? Is there an esoteric way to make transitions to hold partway through? I resorted to pita motion tracking and panning to get the split.
Thank you.
I don't understand why a simple Event P & C + a quick Track Motion is so difficult for you, but that is the simplest way.
Edit : A little further digging (and this is into Vegas Pro - I don't have movie studio) shows that there are envelopes that can be applied to transitions to control transition program. Theoretically, if you have the transition set to run the duration of the clip, you coukld add an envelope to the transition and cause it to hold for that length. Look up transition progress envelopes in the help files for details.Read my blog here.
Thank you. Next time that I need a transition hold I'll check into transition progress envelopes.
Does Sony Vegas Movie Studio HD Platinum 10 do 60fps?
By vid83 in forum EditingReplies: 13Last Post: 7th Feb 2011, 19:33 -
preview mode in the timeline Using Sony Vegas Studio Platinum 10
By JackDalton in forum EditingReplies: 5Last Post: 26th Oct 2010, 04:16 -
How to edit overmodulated audio in sony vegas movie studio platinum 9
By floriday_girl in forum EditingReplies: 1Last Post: 13th Sep 2010, 09:59 -
Sony Vegas Platinum 9.0 & Architech Studio 4.5
By bpinto0805 in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2009, 20:02 -
SONY Vegas Movie Studio Platinum 8.0
By pcanaveral in forum EditingReplies: 4Last Post: 13th Oct 2007, 23:38
