My brother had recorded some tv shows for me from his computer and converted them to .mpg. He put them on an external hard drive after he tested them--looked great--and gave it to me. I copied them to my computer and when I play them--whether on my comp or from the external HD--the color is all distorted. Like black and white but color at random parts.
I took the HD with the files on it to work and tried them on the computers there, and they look great. It's just my computer. Any ideas? TIA!
Go to your graphics card's setup applet and adjust the video overlay settings.
Any idea where I'd find that?Originally Posted by jagabo
And it may be worth noting that these are the only videos this happens on
Unfortunately, it varies with graphics card and driver version. From the Display Properties dialog select the Settings tab, the press the Advanced button. Search for video color settings.Originally Posted by Nathan1
Play the same video in two players at the same time. Is one messed up and the other normal? That indicates a video overlay problem (only one program can use the overlay feature at a time). If they are both messed up you probably have a codec issue.Originally Posted by Nathan1
Note that online players, like youtube.com, don't use video overlay so they won't show the same problem. Quicktime Player also doesn't use video overlay. Try players like WMP, MPC, VLC, KMPlayer, etc. -
In the same folder as WMP (usually c:\program files\windows media player) there is an old version of Windows Media Player called mplayer2.exe. Try running that and WMP at the same time -- instead of VLC and WMP. VLC is a little tricky because it can be configured not to use video overlay and it has its own MPEG splitter and decoder. But I'm leaning toward a problematic MPEG2 decoder.
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
RGB 32 Color Output Playback Problem
By Shone in forum Software PlayingReplies: 0Last Post: 12th Nov 2009, 02:45 -
Philips 5990 -when connnect to TV, screen color distorted
By fayewolf in forum DVD & Blu-ray PlayersReplies: 5Last Post: 5th Apr 2009, 01:36 -
VCR playback distorted at base
By Kalash109 in forum Newbie / General discussionsReplies: 6Last Post: 24th Mar 2009, 12:40 -
Color Playback Problem?
By magikalfly in forum Video ConversionReplies: 7Last Post: 18th Feb 2009, 23:14
