Question I have a video done on a JVC camcorder, Captured it in adobe premiere. Film and audio is good in premiere or any other editing program I use the problem is when it is authored in to a DVD there is no audio video is fine have tried encoding in different formats still no audio even tried encoding in different audio formats no audio can someone help or do I need to capture again in a different format, audio format is PCM.![]()
HELP HELP HELP![]()
Thanks,
SHAOLIN2006
Can you drop one of the VOBs from the authored file into Gspot or MediaInfo? That should tell you if the audio is really missing or just in the wrong format or wrong specification. You can also try playing one of the VOBs back with VLC Media Player and see if the audio shows up. If so, check the audio format.
I am also curious about what authoring program you used? Most would tell you if there is a audio problem. -
Thanks redwudz Downloaded Mediainfo and gspot and vlc player the audio comes up as PCM audthored in adobe encore and window dvd maker importer in adobe premiere used the adobe programs before no problem. But now there is a problem I set my preferences for dv/ntsc sith a 48000 audio mpeg II audio as before but now no audio
help please
If you have PCM audio, it should play back fine on a DVD. PCM, AC3 and MPEG 1, layer 2 are all valid DVD audio formats. PCM isn't used as much as it takes up a lot of space, compared to the other formats.
I don't use Adobe Premiere or Encore, so not much help there. But unless there is something really wrong with your audio, any of the mentioned audio formats should work on a DVD.
You might try a trial version of ConvertXToDVD or even FAVC and see if they can encode and author a DVD from your original DV files. If so, then there may be a problem with Premiere or Encore. Maybe just a setting.
And this may be obvious, but have you tried playing back the DVD on another settop player or on your computer? You may have mentioned that already, so just asking.
And sorry, this isn't advanced video conversion. Moving you to the Authoring (DVD) Forum.
So you have in preferences audio in MP2 format? It's not valid format for NTSC DVD: AC3 and LPCM only, even many standalone players support it. MP2 is OK for PAL. Perhaps thus Encore makes something wrong during muxing.
Hey Thanks everyone, big shout outs to redwudz and noemi7 never got audio on my computer play back but it plays fine on settop players thats thats all that matters
thanks again for all of your help :P :P :P
SHAOLIN 2006
WHAT IS IT THAT YOU SEE AT THE END OF YOUR HAND
YOUR DESTINY
let your fingers point your way 8) 8)
Authored DVD plays 3 seconds audio/No video
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 6th Jan 2011, 14:26 -
Video and audio are out of synch when authored
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 9th Dec 2009, 23:39 -
where is the audio delay time stored on an authored dvd?
By Toastie in forum Authoring (DVD)Replies: 1Last Post: 12th Oct 2009, 07:45 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13 -
Audio Delay in Authored DVD
By deathwalker in forum AudioReplies: 4Last Post: 21st Aug 2007, 20:42
