Newbie question here but it's a simple problem (I hope) that people here will be able to answer:
I had some short videos (AVI) that I converted to play on a standalone DVD player - I used ConvertXtoDVD. At the time I deleted the original AVI files that the conversion was made from.
Now with Windows Media Centre I am wanting to have the files again as AVIs. I simply want to rip my dvds into avi files, with as much quality as can be preserved from the already degraded DVD version, same soundtrack, no advanced settings of any kind.
I tried DvdX which worked great until I did a system restore and now I always get errors. I am currently using Auto Gordian Knot, but as there doesn't seem to be a progress bar, I have no idea how the conversion is going. At some point in the procedure it seemed to open VirtualDubMod (which must have been installed along with Gordian) and it seems to be doing something also.
Other than seeing a blank window with Dub In Progress, there is no sign of what is going on with VDM - although it claims to be busy, I can drag the slider at the bottom of its window with no apparent result, also with the AGK window I can continue to check/uncheck settings, although it maintains a job is in progress.
I realise there is a great deal of complexity to video conversion, codecs, etc, most of which I know little or none about, but even being pretty computer savvy I am amazed at the complexity to what I would imagine to be simple procedures. If I download an avi file, Media Centre can play it. That's all I want. In re-creating an AVI from my DVDs, I don't want to change any advanced settings, I want the resolution the same, the sound the same, is there ANY easier way for me to do this? Output size isn't a concern, it can be as big as it wants to be to retain as much quality as possible.
I realise also that such a newbie enquiry might be met with hostility given the far more advanced questions being asked on this forum, but please help as I've really tried hard to figure all this out for myself, using mutliple tools, and have come no closer to success than my first attempt.
Thanks.
Results 1 to 9 of 9
I've been using Avidemux. It accepts VOBs. Choose MPEG 4 Xvid and under 'configure' use 'Single pass - Quantizer' and set it '1'. The resultant file will probably be larger than the original, but it should look good. You might also play around with the MSharpen filter.Output size isn't a concern, it can be as big as it wants to be to retain as much quality as possible.
Yeah, erm, AvidMux saves the output as some kind of text file full of numbers. I think I'll just give up
Converting .VOB to .AVI
By reysaj in forum Newbie / General discussionsReplies: 11Last Post: 1st Dec 2010, 09:24 -
By reysaj in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 13:56 -
Help with converting avi to vob
By music_freak in forum Video ConversionReplies: 1Last Post: 16th May 2009, 15:04 -
Converting .AVI to .VOB
By agtjones in forum Video ConversionReplies: 3Last Post: 24th Nov 2008, 15:58 -
Converting .avi to .vob
By oldtrout in forum Authoring (DVD)Replies: 1Last Post: 10th Feb 2008, 09:11
