Hello, I come here to seek help with a problem that I am having. I'm trying to convert a SWF (flash file) into a WMV using WinAVI converter.
But as I go through the process of converting I get prompted with a message that says;
"WARNING: Cannot load the DIVER component!"
then I press okay and then;
"Failed to convert"
Can anyone assist me in fixing this problem as I have not got a clue where the problems lies.
thank you in advance.
That's assuming the SWF file has any sort of FLV video stream in it, though. If it's just a regular SWF file, WinFF, SUPER and WinAVI won't know what to do with it.
In that case, your best bet would be to do a video capture of the SWF as it's playing, and then convert the resulting capture to whatever format you need.If cameras add ten pounds, why would people want to eat them?
WMV to MP4 conversion problem
By ajitpals in forum Video ConversionReplies: 1Last Post: 2nd Dec 2010, 04:41 -
wmv to swf superc converter problem ,upload problems
By FLASH23 in forum Video ConversionReplies: 2Last Post: 17th Sep 2009, 09:55 -
wmv conversion problem
By uglijimus in forum Video ConversionReplies: 6Last Post: 11th Jan 2009, 12:30 -
What is way convert swf to WMV or AVI?
By siluet in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2009, 00:33 -
Adding a graphic to either a .wmv or .swf
By pointyskull in forum EditingReplies: 1Last Post: 28th Jun 2007, 08:20
