Please forgive me I am a noob to this. I have been using ConvertXtodvd 2.2 to convert avi files to dvd. When I play the dvd on my dvd player the image is cropped on the left and right hand sides. It doesn't appear to matter if I select full screen or widescreen, it does the same thing.
Am I doing something wrong? When I run the avi on the computer it looks great, widescreen as I would like the DVD to appear.
TIA
Mike
It's called overscan. When you play the finished DVD on the computer you see the entire picture, don't you?
https://www.videohelp.com/glossary?O#Overscan -
Yes, it appears normal on my PC. I saw a sticky note on overscan. Now that I know what it is called I will check out the sticky.
Thank you. -
Resize it in ConvertXToDVD. Be sure to not screw up the aspect ratio.
5.1 to 7.1 - eac3to? Or just duplicate the sides?
By Asterra in forum AudioReplies: 3Last Post: 20th Apr 2012, 06:03 -
MPEG Streamclip aspect conversion actually crops the image!
By Chamelet in forum Video ConversionReplies: 1Last Post: 4th Apr 2012, 11:47 -
Recording from DVR Cable Box to DVD Recorder crops the sides
By Bumbie in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Jan 2012, 14:40 -
AutoGK crops one of my videos !?!
By singjai in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 11:20 -
VLC Crops video but Quick time plays it correctly
By WuTangDvD in forum Software PlayingReplies: 1Last Post: 8th Sep 2008, 17:48
