hi!
I have just one more question about GUI for Muxman...if I am creating a project in PAL settings does my .avi movie have to be in PAL or can it have for example a NTSC framerates...I know that it's quite difficult to convert from NTSC to PAL but then if my video is'n either in PAL or NTSC and in another weird framerate is it then also so difficult to convert from my "weird" framerate to PAL?!?!
please write down which framerates is best (easiest to convert from .avi to .m2v without any errors) while converting a .avi to PAL (.m2v)
all help really appreciated
cheers
michcio
Results 1 to 17 of 17
It can have any framerate you like. It's only the PAL DVD that has to be 25fps.if I am creating a project in PAL settings does my .avi movie have to be in PAL or can it have for example a NTSC framerates
Not if you know what you're doing.is it then also so difficult to convert from my "weird" framerate to PAL?!?! -
thanks for your response
ok here's some information about my video/audio from G-spot:Originally Posted by AlanHK
Code:Codec: XVID Name: XviD Dev ver. 11-Jun-03 Audio Codec: 0x0055 MPEG-1 Layer 3 Info: 48000Hz 115 kb/s tot , Joint Stereo Pics/s = 23.976 Frame/s = 23.976 :( pic ( w x ): 624 x 464
you mean all my menus on the DVD?Originally Posted by manono
well I will encode my .avi with thoes settings (G-spot) to a working .m2v fileOriginally Posted by manono
ragards
michcio -
What's so unusual about 23.976fps? It's the most common AVI resolution when the source is an NTSC DVD.
Eh? Everything on a PAL DVD is 25fps; menus, movie, extras, everything.you mean all my menus on the DVD?
Did you say how you're creating this PAL DVD? There are 2 basic ways to do it with a 23.976fps source. One is to resize to PAL resolution, speed up the video and the audio to 25fps, and encode like that. The other is to resize to PAL resolution, encode the video at 23.976fps, keep the audio the same length, and when done run the MPV/M2V through DGPulldown set for 23.976->25. -
That's standard NTSC.Originally Posted by michcio
Encode to M2V: resize to 720x480, with pulldown to make the framerate 29.997.
Do you REALLY HAVE to make it PAL?
Most PAL TVs and DVD players seem to play NTSC video without any problem.
Give it a try. -
It's hard to find a PAL DVD player that does not support NTSC, so you should definitely look into this possibility before you do a lot of work for no particular reason.
Good luck! -
Originally Posted by AlanHKOriginally Posted by tomlee59
yeah of course I will give it a try and make a NTSC DVD instead...I think my DVD-player (found it in a garbage hahaha and it works just fine!!
) plays NTSC...I think I have seen the NTSC option somewhere...otherwise I'll try to change my DVD to PAL
and then do how manono or AlanHK say...but while creating a NTSC how do I create a .m2v in NTSC format? SRY have always done it in PAL...I use FitCD to create a .avs file to later open it in HCEnc and encode my .avs to .m2v ...I do always select a PAL radio button in FitCD...shall I just unselect it and all should work fine? :O or do I have to do more changes?!
thankfull for ALL answers!
michcio
yay! ok it works with NTSC on my TV!!!
...thank you guys you have saved like 1 day of my life of converting from NTSC to PAL :P
THANK YOU ALL
michcio
Glad to hear that it worked. My motto is "do nothing, and hope for the best." Sometimes, that strategy succeeds, despite itself.
haha yeah cool motto man!!!
In FitCD, look at the "destination" size.Originally Posted by michcio
Three boxes. For PAL probably : 720 X 560 "DVD 720"
For NTSC, it will probably change automatically to 720 X 480 "DVD 720"
If not, click on the little triangle to the right of the second number, it should make that jump to the correct size.
In HCEnc, click on the button "make DVD compliant". That should activate the "3:2 pulldown" checkbox, which will convert the framerate from 23.976 to 29.997 while encoding the MPEG. -
thanks for more help AlanHK!
yeah it does jump to 720x480 (from 720 x 576 :O not 560) when I don't select the PAL buttonOriginally Posted by AlanHK
ah nice ... always when I opened my .avs file in HCEnc there was written in the info window: "use pulldown for DVDOriginally Posted by AlanHK
compliancy" and when I clicked on the "make DVD compilant" button there was written: possible non-DVD compilant fixed...so you say that I do change my FPS by using this setting from 23.976 to 29.997 :O why 29.997. If I know have a subtitle to my video file do I have to change the framerate from 23.976 to 29.997? I have synced my subs with my .avis FPS
cheers and thanks!
michcio -
When applying pulldown the video's length stays the same. The same audio can be used (or made DVD compliant if not already) and the same subs can be used as for the 23.976fps AVI.
thanks manono great then I don't have to change anythingOriginally Posted by manono
michcio -
Sorry, yes 720x576; dumb typo.Originally Posted by michcio
29.997 is NTSC (for TV). 23.976 is NTSC film (based on the 24 fps celluloid film speed).ah nice ... always when I opened my .avs file in HCEnc there was written in the info window: "use pulldown for DVD
Pulldown tells the player to repeat certain frames to increase the number of frames displayed, without having to store actual duplicate frames.
If the subs are in a format that uses time, (eg, SRT) they should be fine. However, if they're in a format that uses frames (eg MicroDVD) you may need to convert them.
Easy enough with something like Subtitle Workshop if necessary.
Look in the file with a text editor and it should be obvious which format is being used. -
ok so I have done a NTSC project but when I open my video file I get my subtitles UNDER the frame of the window..
why is that please help? have I done something wrong while converting something or shall I just raise my subs ???
cheers
michcio
Which to use, DVDAuthorgui or "GUI for dvdauthor" ? Or DVDauthor in batch ?
By halsboss in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 11:00 -
GUI for MuxMan error
By michcio in forum Authoring (DVD)Replies: 20Last Post: 16th Apr 2009, 08:06 -
GUI for muxman - chapter save
By michcio in forum Authoring (DVD)Replies: 3Last Post: 26th Oct 2008, 07:42 -
GUI for muxman - unable to JumpSS
By michcio in forum Authoring (DVD)Replies: 39Last Post: 5th Sep 2008, 19:25 -
question about Muxman error when using Gui For DVD Author
By jimdagys in forum Newbie / General discussionsReplies: 4Last Post: 6th Jan 2008, 23:52
