I have been scratching my head for days trying to get something done. In short the project I am in the middle of is...
I have a source DVD (video_ts) that is letterboxed. I have two goals. One was to demux and remaster the audio. I have done that. I plan to and know how to reauthor a DVD that has two audio tracks. The remastered on one and the origional on another. So far I am good to go. Ideally I would like to crop this film without recompression before reauthoring. I have the m2v file in full resolution. It could use some cropping on all four sides to loose some black bars and look more like it's origional 2.35:1 ratio. So is this possible without reencoding the m2v file? If so what is a good way to do it?
No. Since your goal is to author back to DVD, the resolution has to be 720x480. If you crop, you'll have to resize back to spec. You can't do that without reencoding and as you know, you can't reencode without loss.
Buy My Books -
How about a resizing or upscaling that will have minimal effect on quality?
You seem to have a widescreen 4:3 DVD (letterboxed) and want to crop and resize it to be able to encode it as 16:9. Whether true or not, any cropping and/or resizing requires a full reencode. How well you do the job and how much the resulting video is degraded depends at least partly on how much you know and what tools you use for the job.
I don't use MAC, so I don't know what tools are available there, but I prefer Lanczos for resizing. To my eyes, it gives the best results. Of course, regardless of what you use to resize there will be some loss, but only you can judge if the loss is acceptable.
Buy My Books -
like said before...
not possible, mpeg2 is made of "a jpeg frame and its transformation to the next jpeg frame" (so if you change something in the jpeg frame -like geometry- the remainder will be non concordant)Originally Posted by cleantone
so you must re-encode
PS: 2.35:1 is a valid dvd aspect (like 1:1) but there are just a few dvdplayer able to read it (so crop a 4:3letterbox to 16:9, but not to 2.35
depending on the contents of your file. If your video is basic (not interlaced) almost every soft can produce a not bad result.Originally Posted by cleantone
If your source is interlaced: only mpegstremclip, jesdeinterlacer, avisynth and mine(see sign) can do the job
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
hmm. I don't know if it is interlaced or not. Can you find out from the source material alone? If so how?
open your file in VLC, do not activate "deinterlacing filters".
Do you see comb's effects during playback? if no, the contents of your file is progressive (not interlaced)
By MGadAllah in forum EditingReplies: 33Last Post: 25th Sep 2011, 19:53 -
crop m2v video file
By robbtek in forum Video ConversionReplies: 3Last Post: 17th Feb 2011, 10:58 -
How do you crop off the edges of an mpeg file?
By True Colors in forum EditingReplies: 3Last Post: 11th Dec 2009, 13:04 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
exporting .m2v source files out of fcp without quality loss
By MacNiles in forum MacReplies: 9Last Post: 17th Aug 2007, 08:39
