i'm using ulead dvd-moviefactory to create dvd's with simple menues.
it works nice but there is one problem: when using chapterpoints there
will be a pause when playing in a standalone player (not with a software player), this is very annoying (especially when i burn live concerts or movies).
is there a solution for this?
thanks & regards
Sando
Nope, no way around this with the Ulead product. What you need
to do is create chapter entrypoints within a single MPG file (rather than
burning multiple MPG files as you are doing). I think the
best app to do this is VCDEasy and it's free, but it doesn't
make menus. TSCV, also free, will make menus though and
solves the problem (but is not easy to use IMO).
vcddude -
Like VCDDude said there will always be a pause between tracks. You can use the Ulead software but you need your movie to be one long MPEG. Then make entrypoints/chapters within it.
thnx for the replies,
but as i stated in my first post: i'm creating DVD's (pioneer dvra03)
and not VCD or SVCD.
i am using entry- or chapterpoints in one big mpeg-file and got this problem (only with my standalone player, yamaha dvds520) and not with a software based player.
regards
Sando! -
thnx anyway
i think i'm gonna try some other authoring software.
may be ulead's dvd workshop, it's gonna be out in march.
something for you guys (VCD or SVCD...)??
regards
Sando! -
I use DVD MovieFactory to author and burn DVDs on a Pioneer A03 and I get no pause at the chapter entry points when play on my Sony, Panasonic, or Apex stand-alone DVD players. The only place I get a pause is between multiple-segments. This is not much help.
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 08:48 -
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 20:42 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 07:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
