Hello, I wonder if anyone could help. I have a Pinnacle
DC1000 and make Mpeg2 files which I ultimately want to
export to SVCD.
Since the pinnacle cannot go below 5MBit/s I have 2
questions.
(1) What is the best way to convert the Mpeg2 stream down
to a lower bit rate. (and also the quickest)
(2) What is the correct approach. Create the Pinnacle Mpeg2
file at a high bitrate (say 10MBit/sec) or at the
lowest bit rate available.
Thanks in advance for any help.
Colin.
rempg2mpg can change the bitrate on mpeg2 streams, and it leaves the original GOP struture in tact. It can also scale the size down to 480x480, 352x480, or leave it at 720x480 (x576 for PAL).
It's a small app (~500K) and free too.
direct download http://www.dvd-digest.net/downloads/files/encode/rempeg2v152.zip
You can also use TMPGenc, 30 day limit on MPEG2 encoding for the newer versions, but not on TMPGenc beta 12, or 12a. You can find those in the tools section on your left.
You should capture at the highest bitrate. The best encodes come from the best source. Crap in = crap out
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 10:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
Mpeg2 artifacts at ~high bitrate.
By ronkkrop in forum LinuxReplies: 24Last Post: 13th Apr 2008, 15:06
