Dear all.
I have recently acquired a copy of Pinacle Studio plus Version 11. I have downloaded my clips from my Panasonic HDC HS9 camcorder (which I purchased in the UK) successfully, but when I try to play them I get the error message "Pinqcle Studi 11 is not set up for PAL.
In the set up box under capture source the TV Standard box is set to NTSC and is greyed out, meaning I cannot access it to change it to PAl
I can only presume that the version I have acquired is for north America. Is there a codec I can download that will get around this problem. If not can you suggest anything else.
Also the clips I have downloaded have downloaded with the file extension .MTS Don't know if this will have any baring on the matter. There is a video clip that came with the programme which has the file extension .MPEG and it plays fine.
Appreciatively.
a5teve
	See http://pinnacle.custhelp.com/cgi-bin/pinnacle.cfg/php/enduser/std_adp.php?&p_lva=&p_faqid=15932
 Or use another video editor, I like Ulead VideoStudio.
	Thanks for the reply.
 In answer to your question the version I was using was a copy but I also have a TRIAL Version that came with my Camcorder. I have tried this and got the same error message. after contacting Pinnacle it appears that, although I purchased my camcorder from Curry's in the UK it c with a North American trial version. I wonder how many more people have had the same problem. This software is useless unless there is a patch or some other means of converting it to PAL. Any suggestions
 5teve.
  Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVDBy rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33
  when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57
  PAL to NTSC, NTSC to PAL framerate conversion?By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31
  Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC formatBy Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43
  NTSC to PAL, PAL to NTSC framerate conversion?By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
