i have got a cellphone with bluetooth facility. can i send files from my computer to my pc? with what programme can i do this? plz.
Results 1 to 11 of 11
if i am wrong plz forgive me. but do you mean a cable(with ther nokia pc suite software) which we connect to the pc's USB for transferring files from the pc to the phone?
Though my Motorola Razr cell phone has Bluetooth, I just use a USB cable for transferring files. But I also have the transfer software. As mentioned, you may be able to use Bluetooth for all this, but you would need the Bluetooth PC adapter and the software.
Slight question - I already use my PocketPC's Bluetooth connection as an alternate way of transferring files to my phone, but I can only transfer one file at a time (annoying when you want to transfer a lot of files to the phone
). Could I overcome that limit with a BT adapter connected to a PC? I suspect it's a limitation of the protocol, though.
If cameras add ten pounds, why would people want to eat them? -
Depending on the Bluetooth stack you're using you can batch send files, meaning they're still sending one at a time but it will queue the others and send them consecutively. I use the built-in BT on my Sony Vaio laptop for transferring files to and from my Windows mobile phone all the time, I also use the BT connection for tethering so I can use the internet connection on my phone from my laptop without having to connect the two. Keep in mind that current Bluetooth (2.1 +EDR?) only supports something like 8-10Mb speeds so it isn't going to be very fast moving files back and forth.
FB-DIMM are the real cause of global warming -
I "Bluetoothed" once....between my wife's phone and mine....just to see if it worked....it did.....now where's my phone's USB cable? By the time I get Bluetooth on both phones set up/turned on/activated...whatever...I'd be done by now.
Ah, okay. Yeah, I don't expect high-speed transfers with BT.
I'm only using it to transfer small files to the phones (and I'm too lazy to pull out the USB cord or microSD card
Newbie bluetooth questions
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2011, 05:37 -
Bluetooth driver needed
By planetx in forum ComputerReplies: 1Last Post: 29th Mar 2011, 07:32 -
bluetooth issue
By alintatoc in forum ComputerReplies: 0Last Post: 6th Apr 2010, 11:19 -
Bluetooth Audio From PC
By hawkeyeJP in forum ComputerReplies: 5Last Post: 22nd Sep 2008, 20:01 -
How to Setup Bluetooth
By Nitro89 in forum ComputerReplies: 1Last Post: 10th Nov 2007, 17:55
