I am downloading a file that is mdf (4.4 gigs). I cant use WMP to play it or a DVD player. Do I have to convert? I have Nero 6.6 Burning ROM....
If it's a dvd-video iso then you can try open it with VLC. Or mount it as a virtual dvd using daemon tools. Or burn it using imgburn.
If it is a .mdf file, it was probably created by Alcohol 120% and would be a image file. VLC should be able to open it and ImgBurn should be able to burn it. If it's around 4.4GB, most likely a DVD file, with a VIDEO_TS folder inside. But it may be PAL or NTSC and you may have to convert it to one or the other to play it on a set top player. NTSC is needed for most US players.
Hi, how do I go from the .mdf image to video_ts folder to compress it with dvd rebuilder? Thanks you're awesome!
He just told you: either burn the image file to disc and then rip the disc and convert, or mount the image file to a virtual disc and then rip the virtual disc and convert. He also suggested which apps to try.
burning .mdf to disc for chipped PS2
By kanedakaori in forum MacReplies: 1Last Post: 13th May 2009, 10:00 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 13:01 -
ISO w/ .MDF file
By 3lutz3toe in forum MacReplies: 1Last Post: 5th Dec 2007, 14:22 -
HOW TO BURN Ps2 games MDF/MDS on MAC OSX
By kimkimkimmykim in forum MacReplies: 7Last Post: 2nd Nov 2007, 02:52 -
extracting vobs from mdf files
By uglijimus in forum Newbie / General discussionsReplies: 7Last Post: 15th Jun 2007, 13:15
