    Nov 2004
    Canada
    I routinely have to convert clips from my Panasonic recorder to MP4 files. I usually put them on DVD-RAM with 8 clips of 30 minutes LP material to fill the disc.
    When I use TMPGEnc Xpress 4.0 to convert to MP4, it often takes about same time as the clips to do the converting; ie: 4 hours of material would take 4 hours of real time converting on my 3.0Ghz P4 machine. This is with the material already downloaded to the hard disk by the program.
    Is there other converter program that you would recommend that can do faster with decent quality? I don't need any editing abilities in the program; just plain old converting.
    Note: I have tried a number of programs in the TOOLS section. I found the ones that CAN work with VRO files would only treat the VRO file as one huge clip and give me one huge MP4 file. I need them in their native 8 separate clips/files; which the TMPGEnc Xpress 4.0 does; but painfaully SLOW.............
    H264 video conversion? If so then it's slow even with new computers
    What video encoding settings are you using? Like 2-pass encoding is sloooow.
    And can't you output as mpg files with tmpgenc xpress(no video conversion)? Then you can try convert those mpgs using the x264 converter (use guis like xvid4psp, staxrip) and see if you can get fast speed.
    Nov 2004
    Canada
    Baldrick, Below are my typical settings in TMPGEnc Xpress 4.0:
    MPEG-4 file output: Stream type: ISO MPEG-4 format
    Output container type: Normal
    Vidoe Size: 352 x 288
    Framerate: 29.97 fps (Progressive)
    Rate Control Mode: Constant bitrate
    Average bitrate: 200 kb/s
    GOP length: 30 frames
    B frame setting: none
    Quantization mehod: H.263
    Audio Encode type: AAC encoder
    Sampling rate: 48000
    Channel mode: stereo
    Bitrate: 64 kb/s
    MPEG version: MPEG-4 (ISO/IEC 14496-3)
    This nets me a MP4 file that is watchable; a 55MB file for a 30-minute clip, and it usually takes 30 minutes to encode.
    I am looking for a faster converter, while keeping the total file size as small as possible. Thanks.
