Hello,
I've rendered an image sequence with a framerate of 25fps in 3d studio max. Now i want to go into after effects and burn a blu ray disc with encore. It seems to work fine however i still got some problems due to interlacing i think.
I pressume my image sequence from 3ds max is 25p. However the project settings of ecore only allow PAL 25i at full HD.
Can anyone please give me some advice on how to handle this?
Just encode as 25 fps interlaced. The only issue you should have is a little smearing of the colors.
I think you only have 2 choices.
1) Use standard definition size (720x480) which allows interlaced video, but only at 50 fps. You'll have to double your frame rate. This can easily be done in AviSynth. No promises about how it will look, but it's easy to double the frame rate. Doubling the frame rate on interlaced video might produce motion artifacts - I'm not sure.
2) Use 1080i in your project. 720 video MUST be progressive for BluRay. 1080 and standard definition (at double the frame rate - 50 fps) are the only things that allow interlaced video. 1080i is OK at 25 fps. -
Thanks for your replies. I decided to take the 1080 25i approach.
In after effects i exported mpeg2 blu ray and h264 blu ray with upper and lower fields. I imported these 4 files into encore and tested them with the 25i setting. I also did tests with several bitrates.
The export out of after effects containing a house in a forest environment looks fine when played on my pc. But when played on the HDTV and blu ray player the leaves (details) flicker and when the camera gets around a wall the playback seems to have some delay. I guess at this point there's much to compress for the codec?
Does anyone recognise these symptoms and do you have a solution? -
What are you watching on? An interlaced TV? That might explain the flickering, but encoding progressive wouldn't help in that situation.
You shouldn't see any slowing down during high bitrate sections unless you have an underpowered decoder or too much bitrate for the media. If you exceed ~10 mb/s on DVD you might have trouble.
how to rip a blu-ray movie to a blu-ray disc
By TURBOLENCIA in forum Blu-ray RippingReplies: 1Last Post: 25th Nov 2010, 16:40 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 09:37 -
Blu-ray disc structure to iso disk image
By llee782 in forum MacReplies: 2Last Post: 12th Feb 2010, 02:22 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 12:48
