kindly suggest me how to convert mp3 vbr to mp3 cbr/what software should be used and how.plz.
	Download Audacity. Install Audacity. Open your VBR MP3 in it.
 In Audacity, go to Edit->Preferences->Import/Export. Download LAME. Audacity uses a file called lame_enc.dll to export files as mp3. You will have to tell Audacity where it is. After you are done with that...
 Go to File->Export. It will export the MP3 as a 128kbps CBR MP3 by default. If you want to change it to a different bitrate, hit the 'Options...' button in the dialog box that pops up and select your bitrate.
 This will probably be the easiest and cheapest way to do what you want.
  Need CBR MP3 in FFMPEG encode, can you help?By RogerTango in forum Video ConversionReplies: 7Last Post: 17th May 2010, 21:09
  what is the difference between VBR and CBR of a mp3 file?By sumeshkri in forum AudioReplies: 3Last Post: 19th Sep 2008, 08:31
  Convert divx vbr to cbr audio - video freezes (possible reason & solutiBy lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 16:51
  Convert VBR to CBRBy Pariah69 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 12:32
  Avi.Net VBR MP3By KnightHeart in forum Video ConversionReplies: 0Last Post: 8th Jul 2007, 07:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
