I have some high quality trailers in MKV format that are not capable of being streamed to my Xbox 360. I have a program that can convert these files into .avi which do stream, but are somewhat choppy, almost as though the CPU cannot render the stream fast enough.
The program I use is Aone FLV converter which I use for Youtube videos, however, it can also convert my MKVs for me into a number of formats.
Which format would be the best in this situation for best quality/smallest file size while being 360 compatible?
Which resolution should I use when converting the files?
You could try using GOTSent
How I convert TV shows to be compatible with Apple TV 2 and XBox 360
By Codestud in forum Video ConversionReplies: 5Last Post: 26th Aug 2012, 15:35 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
adding subtitles to xbox 360 compatible 5.1 wmv file
By TF2MarkP in forum Newbie / General discussionsReplies: 3Last Post: 30th Aug 2009, 20:16 -
MKV to Xbox 360
By dbanga in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2008, 09:32 -
Need felp converting MKV file so it plays on Xbox 360
By wwervd316 in forum Newbie / General discussionsReplies: 6Last Post: 7th Mar 2008, 23:29
