Im trying to use FFMPEGX to encode videos to the PSP, I've followed to tutorial on the site and was successful twice...but when i try again, it just quickly makes the bell sound and leaves an empty MP4.
The source format is
Video: H264, yuv420p, 640x360
Audio: aac, 44100 Hz, Sterio
Targer Format:
To: PSP
Video: FFMPEG xvid, 320x240, 300kbps, 29,97fps, no crop
Audio: aac, 24000 Hz, 32 kpbs
(AKA default PSP setting)
Im on a real iMac running OS X Leopard
For some reason there is a problem with 264 encoding on multi-core intel macs... To get around this, you need to disable multi-core support. unfortunately, there isnt a good way to do this with out using terminal.
This is the script I use; you can of course change size, bitrate, codec, etc. rename old.avi to the file you're converting and new.mp4 will be your new file. In case you're curious, -level 21 makes the h264 a format psp and ps3 will understand (not needed if you're using xvid), and -coder 1 limits you to 1 thread/core (or so i've been told). Hopefully this is a good starting point in your hunt, not sure if this solves encode from problems, but it solve my encode to problems.
/Applications/ffmpegX.app/Contents/Resources/ffmpeg -y -i ~/Desktop/old.avi -f mp4 -vcodec h264 -level 21 -s 480x272 -b 1000k -coder 1 -acodec aac -ac 2 -ab 128k ~/Desktop/new.mp4
PSP encoding woes - chipmunks overruning the audio
By Cyntalan in forum Video ConversionReplies: 0Last Post: 27th Jan 2011, 20:48 -
Encoding iPod/mobile + PSP AVC compatible files.
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 11th Sep 2009, 02:42 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
PSP encoding error
By richgone in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2008, 07:06 -
Method for encoding Motion JPEG for PSP
By ByteMe72 in forum ffmpegX general discussionReplies: 6Last Post: 13th Nov 2007, 17:02
