Okay heres my process...
I rip from DVD to ISO with ImgBurn/DVDDecrypter, then i extract the ISO (to VOB) with DVDShrink or ISOBuster, then edit the VOBs in VideoRedo/SonyVegas7, outputting to MPG, i then author the MPG's in DVDArchitect4, output to ISO & burn in ImgBurn.
I dont appear to lose quality but i just want to make sure 100% im not losing anything...
Thanks in advance for any help...
Results 1 to 10 of 10
What do you want exactly to do with the DVD?: cut out something, add special effects or what?
For the OP: Some filters require re-endoding the entire video. For example, if you run a sharpen filter on the entire film the whole thing will have to be re-encoded. Other filters only effect short segements of video. Transition effects for example will have to be re-encoded but with smart rendering only the transition (and maybe a few frames around it) will be re-encoded, not the entire video. Dumb renderers will re-encode the entire video if you make any changes. Sometimes even if you make no changes.Originally Posted by poisondeathray
Any cut GOP where the I frame has to been removed has to be re-encoded. As I understand it VideoRedo allows frame accurate cutting so it has to re-encode the cut GOPs. Of course, with DVD MPEG GOPs are only about 1/2 second so it's hardly worth worring about.Originally Posted by poisondeathray -
I use Vegas to open the VOB's & extract clips for use in future DVD compilations.
I sometimes add intro/outro to the clips for use on ipod/youtube but im not too bothered about the quality there as i output to mp4.
Im more worried about when i render as mpg to save for use on future DVD compilations...
edit dvd without losing quality
By robroth in forum EditingReplies: 8Last Post: 13th Jan 2011, 14:12 -
Shrink DVDs without losing much quality
By ssusca in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2011, 13:57 -
Losing all the quality converting 720p
By TheDizzle in forum MacReplies: 1Last Post: 25th Jan 2009, 13:30 -
Fix the AR without losing quality?
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 19th Jan 2009, 14:35 -
Am I losing image quality when I do this?
By Ronny G in forum Authoring (DVD)Replies: 3Last Post: 26th Feb 2008, 11:22
