Hello, I'm willing to learn how to use just about any program unless it will take me months to learn some coding or whatever. I just need to learn how to convert .mkv and .ogm to .avi while preserving the original subtitles and sound. Learning how to choose which language would also be great. Please don't give me the typical ".mkv is better than .avi I won't help you" response. It's for storage, and .avi is a lot smaller. Thank you in advance.
Results 1 to 16 of 16
No, avi is not smaller. You can make mkv,ogm with same file size because it depends on the video bitrate and not the container(avi,mkv,ogm).
But if you want avi I would use alltoavi or xvid4psp. If you don't want burned in subtitles you must use avimuxgui to add the subtitles to the avi and they will only work if you have vobsub installed. Or you can use separate subtitles. Extract subs from mkv,ogm using OGMcleaver. -
I dislike alltoavi, I've tried it. xvid4psp seems interesting, I'm just confused about how to use it. I do want the subtitles burned in, so the extras shouldn't matter. I can't really figure out how to put the subtitles on. When I go to watch it in Media Player Classic I just choose the subtitle language. It's not a separate subtitle file. Converting it to .avi in general is just confusing. I'm probably gonna need some help here.
Edit: I've got it to go to .avi, still can't figure out subtitles though. -
If you want subs with xvid4psp you must first extract the subtitle from the mkv/ogm. Use OGMCleaver or mkvextractgui. Then load the subtitle under Subtitle->Load in Xvid4psp.
Thank yah! I'll edit this post if I have any issues.
Edit: That's pretty much the most annoying thing ever. I opened OGMCleaver, right, and I opened up my .mkv video and it was all "This doesn't appear to be a .ogm/.mkv file." So, I'm stuck. MKVExtractGUI just gives me errors for no reason, I gave up on that one. -
Are you sure it's a valid .MKV file, and not something simply renamed to .MKV? You might try running it through a utility like MediaInfo to make sure there's nothing wrong with it.
What errors did you receive with MKVExtractGUI? Did you make sure to install mkvtoolnix to the same directory as MKVExtractGUI?If cameras add ten pounds, why would people want to eat them? -
Okay, so MKVExtractGUI is working, and yeah it's installed in the same directory as mkvtoolnix now. So no more errors. I just can't figure out how to get out the subtitles. Also, MediaInfo says that everything is fine with the .mkv file and that the subtitles are in .ass format. OGMCleaver is still being annoying though.
Edit: Got OGMCleaver working! Woot~ Last problem for now, is there a way to get it to extract JUST the subtitles? I find no need for the rest of the stuff.
Edit 2: So, I just started to encode a single episode because I'm cool like that. And it's going along fine, decent speed, doing what it needs to do. The preview video looked good and the subtitles/sound/video were all in sync. Which is good! But, is there a way to bulk encode with XviD4PSP? Because, sometimes you download a batch torrent with like up to 50 episodes in them and you just gotta convert 'em all. I'd like to leave my computer alone for a night, or a weekend while I'm away and just let it run through like a whole season.
Edit 3: It finished, awesome! Right, WRONG! So, the audio and video are off sync. One's slower than the other. I think it's the audio, I can't tell 100%, but I think it's the audio. Subtitles are fun, but I didn't expect them to be off sync. Also note that the preview video in XviD4PSP looked totally fine and was in sync. -
I apologize for bumping this, but I doubt anyone will look here if I don't. I kinda proclaimed victory, but later edited it with some issues.
PLEASE wait some days before bumping.
I would buy/rent the episodes on dvd instead of downloading warez. No sync problems. -
I had more than enough reason to bump. You're obviously around to comment, but I was falling down the page. And I assumed no one cared mainly because I posted that it was fine. Buying/Renting, well, if I wanted to deal with bad quality I could do that, plus, what about the ones I already own and just want better quality subs? That's completely legal, but I still get sync problems.
I waited 3 days, you knew this post was here, and yet no response. I don't like that you'd assume that it's warez when you have no knowledge of what I'm trying to convert. Is that your way of saying "I don't know what your problem is"? I don't think that's a good way to say that... Now, does anyone here know how to get a .mkv to .avi with subtitles, audio, and video all in sync? Like I said, I'm willing to learn just about anything so long as it won't take months to master.
Since you own the original, it would be MUCH easier to go straight to .avi, especially if your .mkv's are vfr (variable frame rate), which they probably are by the sounds of your sync issues. (If they are anime .mkv's and you didn't author them, they are 99.9% likely to be VFR). If you want to do it the hard way, there are several posts revealing how to do this, just [search]
Another approach would be to fix the sync in the avi. This is only possible if the .mkv's were NOT vfr. Again, there are 100's of posts and guides demonstrating how to do this. Make sure you differentiate between a constant delay vs. progressive delay
If you still can't figure it out, despite reading all the posts that deal with the same issue, please post specific questions and details, and someone will help you out -
Oh no! Big error
I'm not totally sure what to do here... Some help please?
Crash reason: Access Violation
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'vobsub'...
...while running filter "TextSub 2.23" (FilterSystem.cpp:520)...
...while running thread "Processing" (thread.cpp:120).
Code:VirtualDub crash report -- build 2540 (release) -------------------------------------- Disassembly: 0abb3420: a5 movsd 0abb3421: bd0a89078b mov ebp, 8b07890a 0abb3426: 4d dec ebp 0abb3427: 0c66 or al, 66 0abb3429: 8b11 mov edx, [ecx] 0abb342b: 52 push edx 0abb342c: ff1594a5bd0a call dword ptr [0abda594] 0abb3432: 83c410 add esp, 10 0abb3435: 85c0 test eax, eax 0abb3437: 741a jz 0abb3453 0abb3439: 8b450c mov eax, [ebp+0c] 0abb343c: 83c002 add eax, 02 0abb343f: 89450c mov [ebp+0c], eax 0abb3442: 668b00 mov ax, [eax] 0abb3445: 50 push eax 0abb3446: ff1594a5bd0a call dword ptr [0abda594] 0abb344c: 83c404 add esp, 04 0abb344f: 85c0 test eax, eax 0abb3451: 75e6 jnz 0abb3439 0abb3453: 8b4d0c mov ecx, [ebp+0c] 0abb3456: 8b442410 mov eax, [esp+10] 0abb345a: 83c704 add edi, 04 0abb345d: 83c102 add ecx, 02 0abb3460: 48 dec eax 0abb3461: 894d0c mov [ebp+0c], ecx 0abb3464: 89442410 mov [esp+10], eax 0abb3468: 75a9 jnz 0abb3413 0abb346a: 8b4d08 mov ecx, [ebp+08] 0abb346d: 83c8ff or eax, ff 0abb3470: 894630 mov [esi+30], eax 0abb3473: 894624 mov [esi+24], eax 0abb3476: 897130 mov [ecx+30], esi 0abb3479: 8d7344 lea esi, [ebx+44] 0abb347c: 8bce mov ecx, esi 0abb347e: e885230200 call 0abd5808 0abb3483: 8b550c mov edx, [ebp+0c] 0abb3486: 668b02 mov ax, [edx] 0abb3489: 663d5c00 cmp ax, 005c 0abb348d: 7423 jz 0abb34b2 0abb348f: 663d7d00 cmp ax, 007d 0abb3493: 741d jz 0abb34b2 0abb3495: 8b7d0c mov edi, [ebp+0c] 0abb3498: 50 push eax 0abb3499: 83c702 add edi, 02 0abb349c: 8bce mov ecx, esi 0abb349e: 897d0c mov [ebp+0c], edi 0abb34a1: e8b2210200 call 0abd5658 0abb34a6: 8b450c mov eax, [ebp+0c] 0abb34a9: 668b00 mov ax, [eax] <-- FAULT 0abb34ac: 663d5c00 cmp ax, 005c 0abb34b0: 75dd jnz 0abb348f 0abb34b2: 8bce mov ecx, esi 0abb34b4: e881210200 call 0abd563a 0abb34b9: 8bce mov ecx, esi 0abb34bb: e874210200 call 0abd5634 0abb34c0: 8b0e mov ecx, [esi] 0abb34c2: 8b41f8 mov eax, [ecx-08] 0abb34c5: 85c0 test eax, eax 0abb34c7: 743a jz 0abb3503 0abb34c9: 6a01 push 01 0abb34cb: 6a30 push 30 0abb34cd: 8d4c243c lea ecx, [esp+3c] 0abb34d1: e82c230200 call 0abd5802 0abb34d6: 8b542434 mov edx, [esp+34] 0abb34da: 8b06 mov eax, [esi] 0abb34dc: 52 push edx 0abb34dd: 50 push eax 0abb34de: ff1598a5bd0a call dword ptr [0abda598] 0abb34e4: 83c408 add esp, 08 0abb34e7: 8d4c2434 lea ecx, [esp+34] 0abb34eb: 85c0 test eax, eax 0abb34ed: 0f94442427 setz [esp+27] 0abb34f2: e8f71e0200 call 0abd53ee 0abb34f7: 8a442427 mov al, [esp+27] 0abb34fb: 84c0 test al, al 0abb34fd: 0f84fa0d0000 jz 0abb42fd 0abb3503: 8b4d14 mov ecx, [ebp+14] 0abb3506: 83c144 add ecx, 44 0abb3509: 51 push ecx 0abb350a: 8bce mov ecx, esi 0abb350c: e8e91e0200 call 0abd53fa 0abb3511: e9e70d0000 jmp 0abb42fd 0abb3516: 33c0 xor eax, eax 0abb3518: 668b06 mov ax, [esi] 0abb351b: 83e878 sub eax, 78 0abb351e: 0f db 0f 0abb351f: 84 db 84 Windows 5.1 (Windows XP build 2600) [Service Pack 3] EAX = 02e35000 EBX = 0c6ef8e8 ECX = 03088968 EDX = 003c0608 EBP = 0c6ef8ac DS:ESI = 0023:0c6ef92c ES:EDI = 0023:02e35000 SS:ESP = 0023:0c6ef7c8 CS:EIP = 001b:0abb34a9 FS = 003b GS = 0000 EFLAGS = 00010246 FPUCW = ffff027f FPUTW = ffffffff MM0 = 00cbdfdfdfcbdfdf MM1 = dfcbdfdfcbdfdfcb MM2 = dfcbdfdfdfcbdfdf MM3 = dfcbdfdfdfcbdfdf MM4 = 843521cfb2b79000 MM5 = af00000000000000 MM6 = a000000000000000 MM7 = af00000000000000 Crash reason: Access Violation Crash context: An out-of-bounds memory access (access violation) occurred in module 'vobsub'... ...while running filter "TextSub 2.23" (FilterSystem.cpp:520)... ...while running thread "Processing" (thread.cpp:120). Thread traces: Thread 00000974 (Main thread) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1828) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1846) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(429) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(569) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(409) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(429) Thread 00000d5c (FastWriteStream) Thread 00000b50 (Processing) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Dub.cpp(2817) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Dub.cpp(2609) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1623) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1658) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Dub.cpp(2614) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(517) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(530) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSequenceCompressor.cpp(403) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSequenceCompressor.cpp(420) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Dub.cpp(2777) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Dub.cpp(2817) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Dub.cpp(2609) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1623) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1658) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Dub.cpp(2614) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(517) Thread 000009dc (Dub-I/O) Thread call stack:0abb34a9: vobsub!?ParseStyle@CRenderedTextSubtitle@@AAEPAGPAVCSubtitle@@PAGAAVSTSStyle@@2_N@Z [0aba0000+12810+c99] 7c809abc: kernel32!lstrlenW [7c800000+9a99+23] 5f80444f: MFC42u!0000444f 7c809abc: kernel32!lstrlenW [7c800000+9a99+23] 5f84dd10: MFC42u!0004dd10 0abb2051: vobsub!?ParseEffect@CRenderedTextSubtitle@@AAEXPAVCSubtitle@@VCString@@@Z [0aba0000+11de0+271] 0abb4d5c: vobsub!?GetSubtitle@CRenderedTextSubtitle@@AAEPAVCSubtitle@@H@Z [0aba0000+144a0+8bc] 7c9101bb: ntdll!RtlAllocateHeap [7c900000+100a4+117] 77c36ef5: msvcrt!perror [77c10000+26df2+103] 0ababe30: vobsub!?vobsubGetSubFileNames@@YAXVCString@@AAVCStringArray@@AAV?$CArray@USubFile@@AAU1@@@@Z [0aba0000+9770+26c0] 0abb1502: vobsub!?Render@CRenderedTextSubtitle@@QAE_NAAUtagBITMAP@@HNAAVCRect@@@Z [0aba0000+11080+482] 0abb1518: vobsub!?Render@CRenderedTextSubtitle@@QAE_NAAUtagBITMAP@@HNAAVCRect@@@Z [0aba0000+11080+498] 7c90d07c: ntdll!NtCreateEvent [7c900000+d070+c] 0abb1071: vobsub!?Render@CRenderedTextSubtitle@@QAE_NAAUtagBITMAP@@HN@Z [0aba0000+11050+21] 01ea1b10: textsub!VirtualdubFilterModuleDeinit [01ea0000+1120+9f0] 0047c4f0: FilterSystem::RunFilters() 0047c296: FilterSystem::RunFilters() 0046e908: Dubber::WriteVideoFrame() 0046f12f: Dubber::ThreadRun() 7c90d37c: ntdll!NtFreeVirtualMemory [7c900000+d370+c] 7c91a4b5: ntdll!RtlReAllocateHeap [7c900000+19b80+935] 7c91a7a3: ntdll!RtlReAllocateHeap [7c900000+19b80+c23] 7c91a53d: ntdll!RtlReAllocateHeap [7c900000+19b80+9bd] 7c90d28c: ntdll!NtDuplicateObject [7c900000+d280+c] 7c80def3: kernel32!DuplicateHandle [7c800000+de8e+65] 0052939f: VDThread::StaticThreadStart() 0056b99c: _threadstartex@4() 7c80b713: kernel32!GetModuleFileNameA [7c800000+b55f+1b4] -- End of report
I'm totally lost with AviDemux, please give me a hand with either VirtualDubMod or AviDemux. (With AviDemux I can get the subtitles to show up in the preview but they are really ugly and look nothing like what they should. The font and coloring is all different and weird as well as placement for some scenes. Even if I do try to encode it, it just gives me a fatal error.)Originally Posted by Xandal
I'm so sorry for the double post, I thought I was editing!
How to convert MKV to AVI or OGM to AVI using mencoder
By Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 12:19 -
How to convert matroska MKV to AVI or OGM to AVI
By Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 01:56 -
Multiple audio, subtitles, OGM, MKV & RMVB issues
By bkfng in forum ffmpegX general discussionReplies: 12Last Post: 17th Jan 2011, 00:05 -
HOW-TO - CONVERT AVI, OGM or MKV to DVD
By Ecko_Blue in forum User guidesReplies: 44Last Post: 19th Sep 2008, 10:10 -
Converting OGM/MKV to AVI
By DarkManX4lf in forum DVD RippingReplies: 11Last Post: 30th Dec 2007, 16:16
