hi
looking for program so i could load dvd files and author with:
-keeping original menu and all setup
-no re-encode option to save files back to DVD structure
does anyhing exist?
can dvdlab pro2 handle this?
thanks
Results 1 to 9 of 9
Just burn the vob,ifo,bup files?
Or do you want to load another video/audio/subtitle and keep the menus?
Or do you want edit the menus?
Or? -
i need to load WHOLE structure of DVD (all menus, chapters, audios..etc)
and than i would like to lets say for example just edit audio tracks (delay cut..)
but it does not matter what i need to do...
most important thing is to KEEP ALL ORIGINAL MENUS and NO-REENCODE OPTION if i save it again or author it back to original structure.
hope this clear... -
I would use pgcdemux to separate video,audio,subs from the dvd.
Fix the video,audio,subs tracks.
Use muxman to author.
Add back the original menus using vobblanker.
See https://www.videohelp.com/guides/category/other-dvd-backup-guides-dvd-to-hd-subtitle-6;34#937
Maybe you could use dvdremake pro also. -
thanks
first option of demuxing and muxman and vobblanker etc is way too difficult...
i may try dvdremake pro which i thought will be most easiest solution....
i tried tmpgenc author which loads all files without remuxing anything...but does not keep menu...which is biggest problem....if this program loads menu..everything is OK but it will not
demuxing is not much solution....i need to load everything into some program and edit there...that is what i meant...thanks for reply...i will try dvdremake pro.....do you know if dvdlab pro2 ES will habndle also my problem? -
DVD Lab will not do what you want.
DVD Remake can do come cutting, but it will cut video and audio at the same time. You can also manipulate DVD setup in there like eliminating unwanted parts, but no audio delay or separate video editing is possible.
Only way to do separate cutting is to demux. -
Then you have no business trying to do what you want to do. All you've said so far is that you want to use DelayCut on the audio. It's a simple matter to demux, use DelayCut, remux using Muxman, and then replace the video into the original DVD using VobBlanker as Baldrick outlined.Originally Posted by deejay.2001
It's the only solution, and an easy one at that.Originally Posted by deejay.2001 -
hi all,
who could give me a full guide for dvdremake pro? what can this product use for? thx in advance. -
Try looking here
http://www.dimadsoft.com/dvdremakepro/info.php
Looking for a BD Authoring software that dont re-encode MPEG2 Files
By faramith in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Dec 2011, 04:39 -
+1 audio steam to the DVD with original menu.
By kurochocho in forum Authoring (DVD)Replies: 0Last Post: 12th Jul 2011, 10:48 -
Original DVD Menu
By cavusozkan in forum Authoring (DVD)Replies: 8Last Post: 17th Feb 2010, 21:54 -
Keep original DVD menu, add new movie file
By Booklet in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2009, 16:21 -
Added subtitles to a dvd but want cant seem to get the original menu workin
By Loonatik in forum Authoring (DVD)Replies: 8Last Post: 9th May 2008, 05:31
