i know that this is the wrong place for this post and this is not a video related question so sorry but did not know where else to put it . a security site i came across recently is asking to be added to my whitelist in order to access certain aspects of it.i have no problem doing this but do not know what is a whitelist and how do i add a site to it?i have tried adding the site to the trusted sites using internet options but this does not work.any help is appreciated
Results 1 to 9 of 9
Whitelist for what? A Whitelist can be used in many programs. For example you can whitelist domains in spam filter program. all other email will be rejected.
I'd caution anyone about "Security sites". Thoroughly research the site before downloading or installing anything. There's more bad apples than good apples and many of these sites are not security sites but instead will trick you into installing things which you there are there to prevent in the first place. -
A "whitelist" generally has more to do with what THEY can do to YOU than what YOU can SEE of THEM. It is also a pretty generic, non-specific term.
A "security" site that wants you to eliminate your security protections, and does not clearly explain in foolproof terms what they want done?
Personally, I would get out the 10-foot pole. -
Originally Posted by deadman1972
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
the website in question is "security-forum.net" and when i try to access the forums section it is asking me to add the domain to my whitelist.as i said i added it to the trusted sites on internet options but that did not work.
could someone please explain what a whitelist is and if internet explorer or xp has one?thanks for all the advice and i did take out the ten foot pole as advised.
in a network environment where net access is governed by the it department, they set windows to block all websites except those they put in as "whitelisted" which only means they are accessable, as apposed to "blacklisted" or a list of banned sites.
probably doesn't apply to you. probably a "feature" of i.e.7 is interfering. try firefox 3.--
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 10:57 -
Ripbot Issue
By Yeomans in forum Newbie / General discussionsReplies: 2Last Post: 12th Sep 2010, 07:28 -
pc to tv issue
By notaclue72 in forum Media Center PC / MediaCentersReplies: 26Last Post: 25th Feb 2010, 12:25 -
Another issue...
By nanook in forum ffmpegX general discussionReplies: 3Last Post: 21st Nov 2009, 08:47
