A series of MP4 video files that I download report the following audio specs in GSpot 2.70a:
mp4a: MPEG-4 AAC LC
32000Hz 96 kb/s tot (2/0)
Presently I use AOA Audio Extractor to extract the audio as a wave file. The resulting wave file is about the same size as the video file. Is there a way to extract the audio portion without converting it to a new format, such as wave? That is, the file that is extracted is the AAC file that is exactly the file that is multiplexed in the MP4 file? The file should be exactly the same quality as the original while being smaller than the wave file.
While I know a lot about audio, I'm not current on AAC (what's LC?) or even MPEG-4. The two objectives of this request are to hopefully demultiplex the audio portion of the file with no recoding.
mp4muxer/mp4creator worked fine on my office computer, but it crashes when I try to run it on my almost identical home computer. Downloading the zip file again did not help. How can I troubleshoot?
The good news is that Easy CD-DA Creator, which I have, handles AAC files!
DTS-HD Master Audio Extraction from Tsmuxer
By m1ke486837 in forum Blu-ray RippingReplies: 0Last Post: 5th Jan 2011, 19:29 -
Mp4, Aac & Wav Extraction
By mahendras in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2010, 08:27 -
MP4 audio extraction (ripping the 5.1)?
By takearushfan in forum AudioReplies: 15Last Post: 13th Sep 2010, 08:12 -
Audio extraction from DVD using VirtualDubMod
By Ogilvy in forum AudioReplies: 4Last Post: 29th Mar 2010, 15:56 -
5.1 audio channel extraction
By efiste2 in forum AudioReplies: 3Last Post: 15th Sep 2007, 04:05
